Frederick Vandenbosch's Blog Low profile wifi on ODROID-W
  • Author Author: fvan
  • Date Created: 8 Nov 2014 8:13 PM Date Created
  • Views 2397 views
  • Comments 11 comments
  • wifi
  • odroid-w
  • raspberrypi
fvan
fvan
8 Nov 2014
I purchased a ODROID-W a while back, and finally decided to fire it up.
As the USB host port is optional, and the connector wasn't provided, I couldn't plug in my wifi dongle. Because of that, I decided to take the dongle apart and solder it to the board without the USB connector. The idea is that this would result in a low profile "onboard" wifi for this already little board (except for the USB host port which would normally be fitted vertically image).
I first soldered the tiny ribbon cable to the wifi module and then to the ODROID-W.
Finally, I put everything in place with a drop of hot glue. And this was the result: a low profile "onboard" wifi module on my ODROID-W.
Whatever project I'll end up using this ODROID-W for, wifi will already be taken care of ...
    mcb1 over 11 years ago in reply to fvan +2
    No sadly not. I also have an Intel Edison and a VoCore waiting for power. (The Edison is in the bottom left corner, the rest is a carrier board) Still mopping up after the challenge, but one major job…
    mcb1 over 11 years ago +1
    Nice work. I hadn't even looked at that option, which makes great sense. Mark
    mcb1 over 11 years ago in reply to shabaz +1
    Yes it is. The biggest problem with it will be the connector which is a very small pitch which dictates SMD, so adding it to your project will be difficult for many. (photo from Sparkfun) Hopefully in…
  • Problemchild
    Problemchild over 11 years ago
    Neat Job and very sensible when you don't have any connectors to worry about should make it more reliable as well if it's bonded to the PCB
  • Problemchild
