Gene Breniman's Blog SMD tweezers adapter for my DSO-TC2 component tester.
  • Author Author: genebren
  • Date Created: 19 Feb 2023 9:32 PM Date Created
  • Views 2402 views
  • Likes 16 likes
  • Comments 6 comments
  • DSO-TC2
  • B&K SMD Tweezers
genebren
genebren
19 Feb 2023
In my prior blog (  TC2-DSO - Subtractive machining a SMT test adapter  ), I used  some shop tools (drill, file and scalpel) to build a SOT23 component adapter.  While this was somewhat successful, I felt that a set of tweezers would be a more useful way to measure 0603 size components. While shopping about, I came across these:
These are SMD tweezer from B&K Precision (TL-8 https://www.newark.com/b-k-precision/tl-8/tweezer-test-lead-smd/dp/96B6798 ). They are SMD  tweezers, connected through a coaxial cable to a pair  of color coded banana plugs.  Having already fabricated a pair of banana jacks to ferrule pins, I simply plugged everything together and inserted the ferrule pins into the component connector on the front of the DSO-TC2.
Next, I test the capacitance of the open leads and the resistance of the shorted leads to get an idea of cable characteristics.
The readings were stable and indicating that future readings could be reasonably accurate. Next I found a loose 0603 10K resistor laying around by soldering space (I am losing a component or two during the assemble process).
Not too bad.  This will be helpful during the PCB assembly process as the tweezers that I use to move components about send one flying.  Once I find it, I can verify that it is in fact the one that I lost and not just a random component laying about (most useful for unmarked capacitors).
Thanks for reading along!
  • baldengineer
    baldengineer over 3 years ago
    You know, I had not about this before, but having a meter dedicated to these tips on my bench would be helpful for random components. Currently, I'm in the habit of just throwing SMTs away when I find them. But, if I had a meter at the ready, I would be more likely to use them!
