Gene Breniman's Blog Some tutorials from an earlier time...
  • Author Author: genebren
  • Date Created: 8 Feb 2018 12:03 AM Date Created
  • Views 1686 views
  • Likes 13 likes
  • Comments 9 comments
  • cpld
  • fpga
  • vhdl
  • embedded
genebren
genebren
8 Feb 2018
A little more than 10 years ago, I did some blogging on another site on various embedded topics.  I hope to redo some of these posts or further expand on some of the topics.  Given some of the recent conversations about FPGAs I thought I might link to some of these older post until I am setup to start re-writing them.
On the topic of VHDL, I generated so tutorials based on some examples of some of the work that I was doing on a couple of different projects/products:
https://www.embeddedrelated.com/showarticle/24.php - VHDL tutorial
https://www.embeddedrelated.com/showarticle/31.php- VHDL tutorial - part 2 - testbench
https://www.embeddedrelated.com/showarticle/43.php  - VHDL tutorial - combining clocked and sequential logic
https://www.embeddedrelated.com/showarticle/54.php  - VHDL tutorial - Creating a hierarchical design
https://www.embeddedrelated.com/showarticle/85.php - VHDL tutorial - A practical example - part 1 - Hardware
https://www.embeddedrelated.com/showarticle/87.php - VHDL tutorial - A practical example - part 2 - VHDL coding
https://www.embeddedrelated.com/showarticle/89.php  - VHDL tutorial - A practical example - part 3 - VHDL testbench
This article was about using a tiny microcontroller to replace some simple logic in a earlier design:
https://www.embeddedrelated.com/showarticle/94.php - Deeply embedded design example - Logic replacement
Enjoy!
Gene
  • fmilburn
    fmilburn over 8 years ago +5
    Hi Gene, I had a look at some of the links and they are nicely done. I'm glad to hear you will be updating them. I keep thinking I will get around to looking at FPGAs and maybe this time I will :-) Fr…
    genebren over 8 years ago in reply to fmilburn +5
    Frank, Thank you for the kind words. If FPGAs are too big or to scary, there are always CPLDs, which is many cases are the better choice when you want to keep cost and/or package size down. A CPLD running…
  • three-phase
    three-phase over 8 years ago +3
    Very good series of blogs with each post building on the one before it. Kind regards
  • fmilburn
    Hi Gene,
    Frank
    • Vote Up +5 Vote Down
    Frank,
    Thank you for the kind words.  If FPGAs are too big or to scary, there are always CPLDs, which is many cases are the better choice when you want to keep cost and/or package size down.  A CPLD running along side of a small microcontroller is often all you need for a tight little embedded system.
    Thanks again,
    Gene
  • eagleenthusiast
    eagleenthusiast over 8 years ago in reply to genebren
    I am curious to know your thoughts on a dividing line between what you would do via FPGA versus CPLD. I am asking for this in the sense of the overall. Not just the cost.
    Obviously, function has to work. But, is it the size of the circuit? One-offs versus a mass build?
    A lot of the feedback I get when I ask is often admitted to be the one they are familiar with. I am hoping that your vast experience will explain to my simpler mind what you think is a good rule of thumb to choose one over the other.
    Please, share your thoughts.
    Thanks,
    Stephen
    genebren over 8 years ago in reply to eagleenthusiast
    Thanks,
    Stephen
    That is a really interesting question.  For me, I would use a CPLD when I am designing a 'co-processor like' function to be used with a microcontroller, or in a very simple design where a 'state machine' would be useful to control another circuit. I would use a FPGA when I am faced with a very large, or very complex design that would benefit from parallel processing.  Also, another distinction that sometimes influences that decision is the necessity of pin-count.  CPLDs can have upwards to 300+ I/O pins, where FPGAs might have well over a 1000+ I/O pins.  Similarly, in a size constrained design (or if you are trying to keep it simple and avoid ball grid array packages) CPLDs might be a better choice than FPGAs.
    I hope that helps.
    Gene
    Thanks,
    Stephen
    I hope that helps.
    Gene
