Gough Lui's Blog Click MR16 LED Globe Failure Post-Mortem
  • Author Author: Gough Lui
  • Date Created: 1 Jun 2016 5:59 AM Date Created
  • Views 3066 views
  • Comments 20 comments
  • fail
  • analysis
  • lighting
  • failure
  • led
  • led lighting
  • teardown
Gough Lui
Gough Lui
1 Jun 2016
One of my regular blog readers submitted an LED globe for post-mortem analysis, having failed well before the expected lifetime. I take a look inside, determine the configuration and analyze the relatively "anonymous" product which seems to show several design shortcomings which I discuss and think might be relevant to other readers at the element14 community.
The article is posted at http://goughlui.com/2016/06/01/failed-click-ltmr5w3k-5w-led-mr16-replacement-globe/
What really gets me is that many products are still designed using multiple-parallel LEDs without any current balancing mechanisms (e.g. remember emitter feedback resistors when paralleling BJTs?) and that leads to potential for a single string to be overstressed continually, fail early, and begin the cascade of failure as other LEDs are forced to soak up current in excess of their ratings, and operate in less efficient regimes resulting in greater heat production and degradation of the semiconductor material. Of course, if you went all-series, you would have an all or nothing situation and require higher voltage driver electronics, but I personally would gravitate to this arrangement for reliability reasons, or go with multiple independent channels if reliability is demanded.
Any comments, or stories related to LED globes or LED light designs are very much welcome.
- Gough
  • Dudley
    Dudley over 10 years ago in reply to Gough Lui +3
    We have absolutely no problem with you or anyone else posting links to blogs on external sites, as long as: It's of interest to engineers It's not spam Obviously we'd rather you blogged here, but we're…
    jw0752 over 10 years ago in reply to shabaz +3
    Over the years I have become used to working under (4) 150 Watt incandescent flood lights. Yes they were hot and probably cost a couple $ a month to operate but I needed to see the cracks and problems…
    jw0752 over 10 years ago +2
    Hi Gough, I am hoping that they do as good of a job figuring out what went wrong with me when I stop ticking as you performed on the LED globe. This is a great learning experience to follow your dis-assembly…
    Hi Gough,
    I am hoping that they do as good of a job figuring out what went wrong with me when I stop ticking as you performed on the LED globe. This is a great learning experience to follow your dis-assembly and analysis of the light.
    I am glad that you are bringing some of these links to your web site onto the Forum.
  • Gough Lui
    Gough Lui over 10 years ago in reply to jw0752
    Love the humour - although I am still trying to find the right level of balance. I find that when I post them around the community, I get the valuable discussion and feedback that I don't otherwise get when it's just sitting on my site, but at the same point in time, I feel a bit guilty of spamming links and I'm sure some people might not appreciate it as much as if the content was posted here directly. But since the content itself is not "directly" involved with element14 equipment, I'm a bit torn between the two, but I suspect if I just use my own "blog" area here, I might not cop as much scorn image.
    - Gough
  • Dudley
    • It's of interest to engineers
    • It's not spam
    Obviously we'd rather you blogged here, but we're aware that's not always practical, you might already have a blog before you came here, or you might have incentives to blog elsewhere, or just prefer the experience elsewhere. And should you have a blog elsewhere, we have no problem with you linking to it.
    Our primary goal is to encourage discussion of electronics and engineering in general, and you linking to your blogs does exactly that. So stop worrying about scorn from us and get posting! image
    I think it's a given as well that on your external blog you might occasionally mention some of our competition, and that's fine too, as long as it's sensible and not blatant promotion.
  • Dudley
    • It's not spam
  • Gough Lui
    Gough Lui over 10 years ago in reply to Dudley
    Thanks Dudley for clearing that up the doubt and for the green light, and thanks for taking the time to pop in here and let me know image.
    - Gough
