John Alexander's Blog Linux-powered rifle brings “auto-aim” to the real world
  • Author Author: Problemchild
  • Date Created: 9 Jan 2014 10:43 PM Date Created
  • Views 2133 views
  • Comments 13 comments
  • guided
  • ces
  • weapon
  • linux
Problemchild
Problemchild
9 Jan 2014
The Idea of gun totting penguins comes to mind but this is the real thing a $17K rifle from a
company from Austin Tx called Trackingpoint
View Through the Sight
The aiming system actually makes the pressure required to pull the trigger change depending on the lock
so it's still possible to fire with out the computer but it's much harder so the human is still in charge of
firing but still it raises ethical questions!
The whole article is here at Arstechnica
  • mconners
    mconners over 12 years ago
    What do you consider the ethical question? We've had guided armaments for quite a while now?
    Mike
  • Problemchild
    Problemchild over 12 years ago in reply to mconners
    Good question , the human selects the target and ultimately pulls the trigger the technology is very much a shooter's aid. The questions I see here are as it becomes a fully automatic system.
    i also wonder about software contributors seeing the Linux OS and what ever OSS software been put into this and similar objects. So my point isn't with this weapon specifically but maybe where it could lead.
    mcb1 over 12 years ago in reply to mconners
    Michael
    Thanks, I haven't watched the video yet, but the varying wind over that distance was also my interest.
    We use ultrasonic wind sensors for work, which had issues when rain squawls came through .... (they now modulate the frequency), but these are only 300mm apart and are bi-directional transmit and receive pairs.
    So I am intrigued.
    I'm also not sure how you counteract a barrel wear ..sure it becomes less accurate, or do they tailor the ammo for the wear?
    2 secs will get you video into the display and 15 secs is not bad at all. (I tend to forget that using ram and the like gets you much quicker up-time).
    Still when the police misfire that emf pulse thing that Cabe blogged about, your Winchester or an AK47 will still work.
  • mconners
    mconners over 12 years ago in reply to mcb1
    Damn right !!! image
  • Problemchild
    Problemchild over 12 years ago in reply to mcb1
    Mark, i wonder if the calibration issues could be worked through by a series of calibration shots at varying distances etc  (obviously not all the time)  when the accuracy starts to drift or I suppose if it can work out where the last round hit it could use that in a process of continuous improvement. Also I expect you are right taht some form of local guestimate of the wind must be calculated and used here not some mythical wind speed somewhere down range.
  • Problemchild
    Cometh the revolution cometh the men
  • mconners
    mconners over 12 years ago in reply to mconners
    http://arstechnica.com/gadgets/2013/03/bullseye-from-1000-yards-shooting-the-17000-linux-powered-rifle/
    interesting read, there are several more articles on that site.
    Mike
  • mconners
    Mike
