John Wiltrout's Blog Acronyms Initialisms Abbreviations and Variables
  • Author Author: jw0752
  • Date Created: 3 Oct 2014 7:17 PM Date Created
  • Views 2030 views
  • Comments 26 comments
  • abbreviation
  • initialism
  • acronym
  • Variable
jw0752
jw0752
3 Oct 2014
       A while back I started a list of abbreviations and acronyms that were being used in the questions and discussions on the E-14 web site. Since I often found myself not able to understand the context of the sentence until I googled the particular sequence of letters I felt that others might be having the same problem. My initial list was entered in the forum a couple months ago and has been viewed over 2000 times. I promised in the initial publication that I would update the list on the forum from time to time. Here is the updated list at this time. If anyone has suggestions for additional entries or if I have gotten any of the below listed wrong please let me know.
I have attached an Xcel .xlsx file for the list below in case you want to save it and make your own up dates.
This post was updated 6/9/16 JCW
8/20/2017
I have attached the latest list of Electronic Initialisms and Acronyms for those who are interested. There are about 750 entries in the list at this time.
Electronics Initialisms.xlsxElectronics Initialisms.xlsx
    jw0752 over 9 years ago +3
    I found a nice list of somewhat older Acronyms and Initialisms yesterday which I integrated into the master list which it is now up to 777 entries. John
  • jc2048
    jc2048 over 9 years ago +3
    You've got most of the ones I could think of. Here are a few more which you might consider: BWO Backward Wave Oscillator (microwave) CDA Current-Difference Amplifier CFA Cross Field Amplifier (microwave…
  • ntewinkel
    ntewinkel over 9 years ago in reply to ntewinkel +3
    Ps, it *really* bothers me when articles use some kind of acronym, take the effort to star* it, and then there is no corresponding lookup line to explain the starred acronym! (or the lookup line is somewhere…
    jw0752 over 9 years ago in reply to dougw
    I will add your information to the list.
    Thanks
    dougw over 9 years ago
    nice list
    BNC should be Bayonet Neill Concelman
    I was always told it was a Baby N Connector, but that was wrong.
    See my upcoming road test for more on this ....
    jw0752 over 9 years ago in reply to ntewinkel
    Thanks for the nice fix. I will make the corrections tonight and implement the duplication scanner.
  • ntewinkel
    ntewinkel over 9 years ago in reply to jw0752
    It's easy to miss one with so many items in the list.
    I had to do something similar a few years ago, merging several lists of similar data for an app I was building.
    I found it was very helpful to use some spreadsheet magic. I thought I'd try it now to your spreadsheet, and it actually just involved adding this formula in C1:
    =IF(A1=A2; "Check please"; ".")
    And then just drag copy it all the way down. There are some duplicate symbols with different meanings, so there's a bit of manual labour still involved, but very little.
    You could compare the descriptions in column B, but that would only find exact duplicates (missing minor wording or punctuation differences)
    (ps, I used OpenOffice, but the formulas tend to work across the board)
    Doing that I found two more:
    ICSP
    PP
    Cheers,
    -Nico
    Great catch! As I was integrating one list into another I must have typed twice or as my family calls them (Senior Moments). I will correct it on my list so future posts will have at least one less mistake.
