John Wiltrout's Blog Cheap Chinese Volt Amp Panel Meter won't zero
  • Author Author: jw0752
  • Date Created: 9 Feb 2020 6:34 AM Date Created
  • Views 9096 views
  • Likes 11 likes
  • Comments 13 comments
  • zero fix
  • panel meter
jw0752
jw0752
9 Feb 2020
A while back I bought 8 of these small 0 to 30 Volt 0 to 10 Amp panel meters from China. I like to use them in my builds because they have in the past worked well for my needs and they are very inexpensive. The other day when I needed one for a new project I found the 4 of the 8 would not zero on the Amp Scale. They would say 2, 3, or 4 in the least significant position and this number would add to the actual current that the meter was attempting to read. This put the meter outside the small trimmers range to calibrate. Further the trimmer had no affect on the meter's 0 level display. I can accept some inaccuracy from these inexpensive meters but I knew I could not tolerate a meter that had a reading when it should have read zero.
I mention this problem in case anyone else has purchased these meters too. Here is what the board side looks like:
I have devised a patch fix to the board that clears the problem and allows the regular I ADJ trimmer to do its job.
I will be glad to share the patch but only if someone has some of these with the same problem. Let me know if you have had a similar problem and I will continue the blog.
  • kmikemoo
    kmikemoo over 6 years ago +5
    jw0752 I have purchased a few of these and, like shabaz , just had low expectations of accuracy. Personally, I'm super impressed that you figured out how to make the adjustment trimmer do what it's supposed…
  • ralphjy
    ralphjy over 6 years ago +5
    Hi John, I've been thinking of trying one of these meters but they don't have much documentation so it's interesting to see your experiences. Have you seen the schematic that was reversed engineered by…
    jw0752 over 6 years ago in reply to clem57 +4
    Hi Clem, It is a hardware resistive trimmer. I will post about it later today since there was some interest. Since I am just a technician there may be some side effects that I am not aware of. A lot of…
  • ralphjy
    Hi John,
    I've been thinking of trying one of these meters but they don't have much documentation so it's interesting to see your experiences.  Have you seen the schematic that was reversed engineered by UpcycleElectronics? https://github.com/Upcycle-Electronics/DSN-VC288
    Can't vouch for the accuracy but you could probably verify it.  Looks like they are using the A/D on the STM8S103F3 MCU for the measurements.
    I also found this reference but don't know if it works: https://www.ittsb.eu/forum/index.php?topic=1351.0
    Hope this helps.  I'll probably get one of these to play with.
    Ralph
    • Vote Up +5 Vote Down
    jw0752 over 6 years ago in reply to ralphjy
    Hi Ralph,
    Thanks for the great information. I will have some fun tonight checking it out and if that reset works you will have saved me a lot of hassle putting my patch on the units when a simple reset does the job. This is what is so great about the forum, every time I come with the intention to help someone else I end up being helped more myself.
    Hi Ralph,
