John Wiltrout's Blog Check out the Interesting Telephone System Power Supply
  • Author Author: jw0752
  • Date Created: 7 Sep 2018 3:44 AM Date Created
  • Views 1246 views
  • Likes 8 likes
  • Comments 8 comments
jw0752
jw0752
7 Sep 2018
Today I pulled an old telephone system out of a store that was no longer using it. The one thing that caught my eye was this Harmer Simmons RD 219 Power Supply. It is a beast of a linear power supply with +/- 24 Volts at 4 amps and 5 Volts at 7 Amps.
Weighing in at 11 kilograms it would probably make a pretty good boat anchor. Here are some internal pictures.
Based on the date codes on the chips this is mid 1980s technology and it was probably considered pretty good quality. Taking the nominal ratings we have a potential 500 Watts of line power with an output of about 250 Watts. The unit still works but it has a moderate 60 Hz hum from the transformer. This unit is probably totally obsoleted by today's Switch Mode Power Supply technology. Some of the first SMPS were making their debut in the early 1980s but they were not very wide spread by the mid 1980s from what I can gather. There may have been other considerations for using a large linear supply to power telephone systems as well.
If anyone has any ideas for a good use for it let me know. In the meantime it will join the collection of things rated too cool to salvage.
    shabaz over 8 years ago +5
    Hi John! It looks really nice : ) It could be sold as an audio supply for those who want no switch mode noise maybe. The +-24V outputs could be handy for that! I was wondering, did you clean it, or was…
  • fmilburn
    fmilburn over 8 years ago +5
    What a monster
    jw0752 over 8 years ago in reply to shabaz +5
    Hi Shabaz, All I had to do was blow off a little dust otherwise this is how I found it. I got a bunch of Business Com circuit boards too and I have been studying and crossing the chips. My boards are usually…
    jw0752 over 8 years ago in reply to dougw
    Hi Doug,
    I would not have thought of it but this may be a fairly fun thing to do. I will look for an amplifier and then Frankenstein this power supply onto it. If I can actually do it I will be back with a Blog entitled Frankenamp arises.
    dougw over 8 years ago in reply to shabaz
    I'm with shabaz - it would make a great audio amplifier power supply. There are lots of low-cost amplifier kits out there, but they lack the (expensive) power supply to turn them into complete systems.
    Jan Cumps over 8 years ago
    I thought there was not enough heatsink for a linear supply with that power. But the sinks are on the bottom.
    Loads of energy must have been burned away in that monster...
    DAB over 8 years ago
    Now that is a power supply.
    If nothing else it is worth a lot of money just to recycle the copper in the transformer.
    mcb1 over 8 years ago
    Given the date of the supply, the PABX phone system of it's time would have been rather large as well, so the weight isn't an issue.
    While SMPS were around, I would think that for long term 24/7 operation you're starting to get into a few years before the passives start aging.
    I would also imagine that many of the companies building these beasts were set in there ways, but now the trend is to assemble from sourced parts so they go with what is more cost effective.
    I like linear supplies ... they don't go bang. image
