John Wiltrout's Blog I Need an Extra Finger
  • Author Author: jw0752
  • Date Created: 10 Sep 2014 6:09 AM Date Created
  • Views 1980 views
  • Comments 26 comments
jw0752
jw0752
10 Sep 2014
Since I retired a couple years ago I have returned to my life long interest in electronics. What I have discovered is that I had not kept up with the technology. The manageable, through the hole, components that I was familiar with in the past have been replaced by something that is very small and solders directly to the surface of the board. Not wanting to miss out on playing with some of these really neat goodies I decided to begin to acquaint myself with the components and the new techniques I would need to learn. While I have been soldering for 55+ years I have seldom had to deal with the soldering of leads so closely spaced. To assist in trying the surface mounted chips I bought some Capital Advanced adapter boards from Newark Electronics and proceeded to attempt to solder the chips to them. The most difficult part was keeping the chip in place while I soldered the first leg. I was explaining to my very supportive wife how difficult it was not to disturb the position of the chip while soldering and in her usual intuitive way she volunteered to hold the chip with her finger while I soldered it. ( At this point she had not seen the size of the chip in question ,1.5mm x 2.5mm) While it was not practical for her to hold it, as usual she was right, what I needed was an extra finger.
I got together the following materials:
30 cm of bare 12 gauge copper wire
4 screws
piece of spring
6 cm of 3 mm brass tubing
20 minutes later after bending and soldering the pieces together I had cobbled together THE FINGER
I got one of the Capital Advance boards out and an LM 3410 LED driver that I wanted to try out.
I placed the IC on the board under THE FINGER. Once it was held down by the finger I made the minor adjustments needed to position it properly.
Now all that was left was the still challenging job of soldering the legs of the LM 3410 to the board.
Final product:
Now all that was left was to plug the LM 3410 LED Driver into a breadboard and wire up the circuit to see if it really would drive 5 series LEDs off of a 3.3 volt supply as advertised.
Not much to look at but it works as advertised.
Good Night Guys 1:10 AM
    jw0752 over 11 years ago in reply to fvan +3
    "The Finger" a la Frederick Or better for soldering access John
    mcb1 over 11 years ago in reply to shabaz +1
    Ah yes but then we John describes using it to solder the "latestwzizbangIC" the headline might read. John gives "latestwzizbangIC" the finger probably not the headline he wants.... Mark
    jw0752 over 11 years ago in reply to DAB +1
    Thanks DAB - By the way I have on my to do list getting a copy of your book. It sounds very interesting. John
  • fvan
    fvan over 11 years ago
    It's like a mouse trap for tiny ICs image well done!
    Frederick
  • michaelwylie
    michaelwylie over 11 years ago in reply to jw0752
    You should make some as gifts. Then people can say you gave them "The Finger".
    ...sometimes I think I'm so clever when I come up with an idea, then I read what I wrote ....
    jw0752 over 11 years ago in reply to michaelwylie
    Hi Michael, I will make certain that I "Gift" Then just to avoid confusion.
  • fvan
    fvan over 11 years ago in reply to jw0752
    Excellent execution on the mouse trap image From idea to working prototype is just hours, great!
    Frederick
  • fvan
    Frederick
    mcb1 over 11 years ago in reply to fvan
    2 hours an 1 minute to be precise.
    Does this qualify as "John builds a better mouse trap".?
    mark
