    • Avnet Boards Community
John Wiltrout's Blog Shop Tips  -  Lint Roller Clean Up
  • Author Author: jw0752
  • Date Created: 23 May 2017 4:43 AM Date Created
  • Views 579 views
  • Comments 5 comments
  • shop_tips
jw0752
jw0752
23 May 2017
It has been a while since I did the last Shop Tip Blog. These are blogs about some of the simple things I have discovered that make working in my shop a little easier. Today I realized that I had not mentioned how useful a Lint Roller can be.
When I have finished a build or a salvage operation on a piece of electronic equipment there is always a mess of debris, metal chips, wire snips, and solder splatter left over. To me, it is very important that none of this debris gets to the floor. The floor is cheap laminate wood and if the small bits of metal get picked up by the casters on my chair they act like little grinders and will eventually wreck my floor.
I begin my clean up by picking up the larger pieces or whisking them into the garbage. The solder splatter is scraped off the glass plate that I usually work on and saved for recycling. This leaves the glass plate and bench relatively clean but there are always smaller pieces that are left over. This is where the Shop Tip comes in.
This is an inexpensive lint roller that is intended to clean lint from clothing. I get them for $1 at the dollar store.
It is a roll of very thin sheets that have a tacky surface. When the sheet becomes saturated with debris it can be pealed off to expose a new surface. I use the roller to clean the surface of the work bench as a final touch to pickup the debris that is missed by the whisking and scraping. This has kept my floor free of caster damage.
Here is what the roller looks like after a typical use.
    balearicdynamics over 8 years ago +3
    Ot's one of those products that can't be missed in a home with a cat or a dog... Also very useful finding lost SMD components. The more durable and cheap is from IKEA. Enrico
    DAB over 8 years ago +2
    Great tip John. I just used the vacuum, but then you tend to run a much cleaner building environment than I do. DAB
    jw0752 over 8 years ago in reply to DAB +2
    Hi DAB, A vacuum works just as well but a couple of times I got more than I wanted and had to open the bag to retrieve some hardware or a part. John
    Great tip John.
    I just used the vacuum, but then you tend to run a much cleaner building environment than I do. image
    Hi DAB,
    Hi DAB,
    beacon_dave over 8 years ago in reply to jw0752
    now that sounds like a problem looking for a solution...
    next project perhaps ?  image
  • gadget.iom
    gadget.iom over 8 years ago in reply to beacon_dave
    Perhaps a vacuum cleaner with a built-in part sorter. image
