NexGen Flight Simuator Documents: Synchro and Resolver Handbook and Guide
  • Author Author: phoenixcomm
  • Date Created: 17 Feb 2025 12:07 AM Date Created
  • Views 2800 views
  • Comments 11 comments
  • flight simulator
  • nexgen
  • synchro
  • hardware
  • Synchro Handbook
  • Synchro Application Guide
phoenixcomm
phoenixcomm
17 Feb 2025
imageIf you work with robotics, avionics, an other fields that use angles you might just run into one or more these things. They are motor like devices that can transmit, or receive angles called Synchros in older aircraft they are used in pairs, imagea transmitter (tx) and a receiver (rx) . As you can see in Figure 1 by moving CG the CR will move exactly in step with its counter part. This figure is from Synchro Application Guide. There is lots more information in the Synchro handbook.
    dougw over 1 year ago
    It has been decades since I've seen a synchro-resolver...
  • ralphjy
    ralphjy over 1 year ago in reply to dougw
    I haven't used them since the late 70's when I left avionics.  I think I still have some size 11s buried somewhere in storage.
    beacon_dave over 1 year ago in reply to ralphjy
    Late 80's here but they were used on antenna rotation gear to provide a remote readout of Az/El angles.
    Later moved to rotary encoders and digital readouts for computerised control.
  • ralphjy
    ralphjy over 1 year ago in reply to beacon_dave
    I first encountered them as a systems engineer when I worked on retrofitting the A-6E with the Carrier Airborne Inertial Navigation System (CAINS).
  • phoenixcomm
    phoenixcomm over 1 year ago in reply to ralphjy
      ralphjy   Never guess who I worked for on the Island? Duh, yup Mother Grumman! and You will never guess where our lab was? Nope. In the building that had the E6x Antenna on the damn room!! And our two PE machines where under it. Across the hall from the F16  no fuselage but every movable part on B-Line strut that you can buy at you local electrical distributor, I think they called it a Green Monster as the strut was green. LOL ~~ Cris
  • ralphjy
    ralphjy over 1 year ago in reply to phoenixcomm
    phoenixcomm small world!  I never made it back east for the flight test as it was considered a minor retrofit and our field engineer handled it.
    Those were the good old days - our Litton facility in San Fernando Valley was located next to farmland.  Nowadays that area is all shopping malls and has a few high rise buildings.
