NexGen Flight Simuator Documents: Synchro and Resolver Handbook and Guide
  • Author Author: phoenixcomm
  • Date Created: 17 Feb 2025 12:07 AM Date Created
  • Views 2821 views
  • Comments 11 comments
  • flight simulator
  • nexgen
  • synchro
  • hardware
  • Synchro Handbook
  • Synchro Application Guide
phoenixcomm
phoenixcomm
17 Feb 2025
imageIf you work with robotics, avionics, an other fields that use angles you might just run into one or more these things. They are motor like devices that can transmit, or receive angles called Synchros in older aircraft they are used in pairs, imagea transmitter (tx) and a receiver (rx) . As you can see in Figure 1 by moving CG the CR will move exactly in step with its counter part. This figure is from Synchro Application Guide. There is lots more information in the Synchro handbook.
    dougw over 1 year ago
    It has been decades since I've seen a synchro-resolver...
  • phoenixcomm
    phoenixcomm over 1 year ago in reply to dougw
     dougw You do realize that a synchro and a resolver are not the same animal. Synchros have 2 wire rotor with a 3 phase stater.   is very different. it has 1 input winding and 2 output winding ie 4 wires, The resolver is basically  transformer that is wound in quadrature form. as it  name implies it resolves angles. ~~ Cris
  • phoenixcomm
    dougw over 1 year ago in reply to phoenixcomm
    Not my most informative comment...Persevere
