NexGen Flight Simuator Hacking a Blu-ray Player with Ethernet & WiFi
  • Author Author: phoenixcomm
  • Date Created: 14 Apr 2018 9:40 PM Date Created
  • Views 615 views
  • vbr210
  • blu-ray player
  • hacking
  • bcm7630
  • linux
phoenixcomm
phoenixcomm
14 Apr 2018
Ok for me this is off topic but it is something that I am meddling about with. I picked up a dead Blu-ray player with no drive, but it does have a nice RJ-45 and an internal WiFi transceiver sticking out of the back, and a neet black front panel. Now as it happens the thing also is written in Java. image
THE PLAN: is to make it see my NFS mounted library, and to play them like locally mounted media.
THE ANALYSIS: I have included my configuration, see the table below. Checking around I found out that the player runs a Linux kernel 2.6.28.9 from elinux.org. I have also found an unpopulated 13 pin connector, If you notice on the lower right there is a label, covering J8, see the table below.
Configuration Table
Part NumberQuanDescription
BCM76301CPU
NT5CB128M8CN-CG2DDR DRAM, 128MX8, 20ns
NT5CB64M16AP-CF1DDR DRAM, 64MX16, 20ns
HY27UF082G2B-TCPB1Flash, 2 GB, 256M x 8bit
J8 Pinouts
PIN
NeumonicNOTES
1BSC_M_SDA0
2BSC_M_SCL0
3I2S_DATA3
4I2S_DATA2
5I2S_DATA1
6I2S_DATA0
7I2S_LR
8I2S_CLK
9(AUD_FS_CLK0)
10(AMUTE)
11(GND)
12(5v)
13(+12v)
OK, now you see all the pretty pictures.   I still need to dig around for more info on this project.  See you all in part 2
Stay Tuned More to Come.
~~ Cris  image
