NexGen Flight Simuator Nexgen: CANaerospace: RSS: C-3436A Radio: Build iiia
  • Author Author: phoenixcomm
  • Date Created: 4 Sep 2021 9:47 PM Date Created
  • Views 744 views
  • offtheshelfch
  • flight simulator
  • nexgen
  • c-3436a/arn-30d
  • rss
  • canaerospace
phoenixcomm
phoenixcomm
4 Sep 2021
imageSo, before I waste some more of my time, I have decided to test the frequency selector pin-outs on P1. So what I decided was to put 5 LEDs on some perf-board with their resistors. Then connect them to the P1 (H-L and then (N-R) with wires between them run P1 (S) to ground, the LEDs to +5vdc, turn the dial on the radio, and see what happens in other words, I don't know if I can trust myself.  The results will be in the table below. Well, I wasted yesterday trying to re-ring out my cables nothing worked. My Fluke 113 continuity would work if I touched the probes together, but not when the cable was installed. It turned out to be just a week battery. And just to make matters worse I must have wired the DB-25s in some weird way. So my pin-out schematic was rubbish. So The only way to ring out J1 (frequency selectors) is to put an Arduino Mega to work and write so software that will read all the pins and prints them on the terminal. Looks Like J2 is ok, but I am not hooking up the volume control. I will get around to reading the resistance of the potentiometer, later
FREQ MC5 MC4 MC3 MC2 MC1 FREQ KC5 KC4 KC3 KC2 KC1
17 5 18 6 19 20 8 21 9 22
BLANK .00
108 .10
109 .20
110 .30
111 .40
112 .50
113 .60
114 .70
115 .80
116 .90
117
118
119
120
121
122
123
124
125
126
J1 Signal Pin Arduino J2 Signal PIN Arduino
30 D30 1
2 D31 2
3 D32 3
4 D33 4
5 D34 5
6 D35 PWR ON 6 D22
7 D36 7
8 D37 Power 8 D23
9 D38 LIGHTS 9 D24
10 D39 A-OUT 10
11 NA 11 NA
12 NA 12 NA
13 NA 13 NA
14 D40 14
15 D41 15
16 D42 16
17 D43 17
18 D44 18
19 D45 19
20 D46 20
21 D47 A-IN 21
22 D48 22 GND
23 D49 23
24 NA 24 NA
25 NA 25 NA
