NexGen Flight Simuator NexGen: Component Documentation: Gables ATC panel: G-1981
  • Author Author: phoenixcomm
  • Date Created: 25 Aug 2022 8:45 PM Date Created
  • Views 1220 views
  • diy cockpit
  • radio interface
  • nexgen flight simulator
  • software
phoenixcomm
phoenixcomm
25 Aug 2022
Gables Engineering ATC Panel
G-1981
Connector Equipment Mate
J1 MS24264R22B55P MS24266R22B55S
Please note the table below in arranged by function
PIN Connects To: Terminal: FUNCTION db25 ARDUINO MEGA Connector
SQUAWK CODES
2 S1A B POS 3xx A1 22
3 S1A C A2 23
4 S1A D A3 24
5 S1B E POS 4xxx A4 25
6 S1B F A5 26
7 S1B G A6 27
9 S2A N POS 2x A7 28
10 S2A O A8 29
11 S2A P A9 30
13 S2B J POS 1 (units) 10 31
14 S2B K A11 32
15 S2B L A12 33
TRANSPONDER #1
16 S8A IDENT A13 34
21 S5 LO SENS A14 35
22 S3 STBY A15 36
23 S3 ON A16 37
24 S4 MODE A A17 38
25 S4 MODE B A18 39
26 S4 MODE D A19 40
19 TEST A20 41
43 S5 ANN.  LIGHT A21 42
TRANSPONDER #2
18 IDENT B1 43
32 LOW SENS B2 44
33 S3 STBY B3 45
34 ON B4 46
28 S4 MODE A B5 47
29 S4 MODE B B6 48
30 S4 MODE D B7 49
42 TEST B14 50
44 ANN. LIGHT B15 51
ALTITUDE REPORTING SW
GND S6 AC+BC B16 na
1 S6 ALT REPORT B17
45 S6 A1 COMPUTER 1 B18 52
46 S6 A 2 COMPUTER 2 B19 53
LIGHTS
38 PANEL LAMPS B11 Relay #1 1NO
39 PANEL LAMPS B23 Power Supply Ground
41 DIAL LIGHTS B21 Relay #2 NO
40 DIAL LIGHTS B9 Power Supply Ground
CHASSIS GROUNDS
8 B13
17 B25
SPARE PINS (NOT USED)
20, 27, 31, 35, 47, 48, 49, 50 51, 52, 53, 54, 55
    DAB over 4 years ago
    Hi Chris, where did you find this little beauty?
  • phoenixcomm
    phoenixcomm over 4 years ago in reply to DAB
    I have had it for about 7-8 years..
