NexGen Flight Simuator NexGen: Component Documentation: Gables Comm Panel: G-4214
  • Author Author: phoenixcomm
  • Date Created: 1 Sep 2022 12:25 AM Date Created
  • Views 621 views
  • flight simulator
  • nexgen
  • Comm Radio
  • diy cockpit
  • gables
phoenixcomm
phoenixcomm
1 Sep 2022
Gables Engineering Comm Panel
G-4214
EQUIPMENT MATE
Deutch DL60R-22-55P5-6116 MS MS
Please Note that this radio only has one tuner even though there are two frequency Selectors. The Transfer Switch controls the radio's frequency.
2 of 5 Code
No. A B C D E
0 X X
1 X X
2 X X
3 X X
4 X X
5 X X
6 X X
7 X X
8 X X
9 X X
PIN FUNCTION J1 J2 MEGA
1 Whole MHz TENS-A 1
2 Whole MHZ TENS-B 2
3 Whole MHz TENS-C 3
4 Whole MHz TENS-D 4
5 Whole MHZ UNITS-A 5
6 Whole MHZ UNITS-B 6
7 Whole MHZ UNITS-C 7
8 Whole MHZ UNITS-D 8
9 Whole MHZ UNITS-E 9
10 FRAC: TENTHS-A 10
11 FRAC: TENTHS-B 11
12 FRAC: TENTHS-C 12
13 FRAC: TENTHS-D 13
14 FRAC: TENTHS-E 14
15 FRAC: HUNDREDTHS-A 15
16 FRAC: HUNDREDTHS-B 16
17 FRAC: HUNDREDTHS-C 17
18 FRAC: HUNDREDTHS-D 18
19 FRAC: HUNDREDTHS-E 19
20 Alternate Modulation (not connected)
21 Frequency Selector Common 25
22 Squelch ~ HI - input
23 Squelch ~ LO - Com
24 Squelch ~ ARM - Output
25 Comm Disable
26 Whole MHz TENS-E 20
27 Power On/Off
28 Power Common
29 SPARE
30 115vac
31 AC power Common
32 Panel Lamps 5vac
33 Panel Lamps GND
34 DC power common (Chassis)
35 Transfer Light +28v
36 FRAC MHz THOUSAND-B 22
37 FRAC MHz THOUSAND-C 23
38 Comm Test
39 SPARE
40 Dial Lamps 5v
41 Dial Lamps GND
42 SPARE
43 SPARE
44 SPARE
45 SPARE
46 SPARE
47 Sharp Selectivity
48 SPARE
49 SPARE
50 SPARE
51 SPARE
52 SPARE
53 SPARE
54 SPARE
55 SPARE
