NexGen Flight Simuator NexGen: Component Documentation: Indicator, Fan Speed, N1
  • Author Author: phoenixcomm
  • Date Created: 8 Oct 2022 7:59 PM Date Created
  • Views 681 views
  • N1 speed indicator
  • flight simulator
  • nexgen
  • ge
  • diy cockpit
  • instruments
  • 8DJ176
phoenixcomm
phoenixcomm
8 Oct 2022
Manufacturer:
GE Aircraft Instrument Div
purchased by AMETEK
Part Number:
8DJ176LZD2
MODS: A, B, C, D
Instrument Clamp:
Marmon: MBG69239
Weight:
Cable Weight:
image image
Front Rear
PIN FUNCTION PIN FUNCTION PIN FUNCTION>
A 4 vac Lighting H
Fan Speed #1 0-5v dc signal
f SPARE
B 4 vac return J Fan Speed #1  Return C Index Drive +12v Reference
U
CASE GROUND
V Fan Speed #2 0-5v dc signal G Index Drive Signal
S 115 v 400Hz Power W Fan Speed #2  Return E Index Drive Signal Return
T 115v 400Hz Return R Fan Speed #1 Over-Limit Switch j N/A
a 28vdc Power for Speed Transducer P Fan Speed #1 Over-Limit Return h N/A
D Fan Blade Pulse Signal #1 N Fan Speed #2 Over-Limit Switch Z N/A
K Fan Blade Pulse #1 & #2 Return c Fan Speed #2 Over-Limit Return Y N/A
F Fan Blade Pulse Signal #2 L 28vdc Fan Overspeed Pointer Reset W N/A1
C N/A M Overspeed Pointer Reset Return - Ground d N/A1
b N/A1
g SPARE
1MODELS: 8DJ176LW32 & 8DJ176LW32LZD2
