NexGen Flight Simuator NexGen: Component Documentation: Indicator, Marker Lights
  • Author Author: phoenixcomm
  • Date Created: 27 Oct 2022 10:43 PM Date Created
  • Views 830 views
  • flight simulator
  • nexgen
  • hardware
  • 1943-4
  • ILS marker lights
  • TELLLITE
phoenixcomm
phoenixcomm
27 Oct 2022
NexGen: Component Documentation: Indicator, ILS Marker Lights
Manufacturer: TELLLITE
Master Specialties
Part Number 1943-4
Lamps: T1 3/4 Midget Flange Base
2 each display
Lamp Voltage not sure yet
image image
Notes:
  • 10.29.2022 - Updated the schematic of the harness and interface
  • 7.5.2024     - Updated in the above schematic I no longer use relays  as I will be using optoisolators (MCT275) and 12vdc lamps
  • 7.7.2024     - Updated currently I am using an 8' length of  Cat5 patch cord which terminates with an RJ45 (LRU) and is soldered to the lamps since the cable has 8 conductors, 6 are for the lamp power and 2 are for the returns.
  • Also, I have included a 7th optocoupler for a Lamp Test function, yet it has to be implemented. ~~ Cris
  • image
  • phoenixcomm
    phoenixcomm over 4 years ago in reply to dougw
    Just a flight simulator (the cockpit) HI REL my cockpit is just like you would find in the military or a commercial simulator.
    This is not like your MS flight sim or Xplane etc.
    dougw over 4 years ago
    Are you building a whole aircraft or what? Relaxed
