NexGen Flight Simuator NexGen: Component Documentation: King Radio: ADF Panel
  • Author Author: phoenixcomm
  • Date Created: 23 Nov 2022 10:40 PM Date Created
  • Views 703 views
  • flight simulator
  • nexgen
  • diy cockpit
  • arduino mega 2560
  • hardware
  • KI266
  • dme
  • software
  • king radio
phoenixcomm
phoenixcomm
23 Nov 2022
NexGen: Component Documentation: Indicator, DME
KI266
Manufacture King Radio
Model Number KI266
Part Number 066-3047-00
Gorn Electronics  GM-14M
Mate: Winchester MRA 14N7
"Gas-discharge displays are used to digitally display range, ground speed, and time-to-station information. Range information is read out to the nearest tenth nautical mile up to 99.9, afterward the decimal point blanks and the display reads out to the nearest nautical mile up to 250 nautical miles. A push-button switch is used to select between ground speed or time-to-station information in the right-most display."
"Ground speed reads to 400 knots and time-to-station reads to 99 minutes. Each display is annunciated by back-lit nomenclature. The displays and nomenclature are automatically dimmed with changes in ambient light (detected by a photo sensor located behind the dead front panel). A rechannel warning light, used only when the DME system includes a hold feature, is also located behind the front lens."
10JAN2024 This device uses 2 SP-333 Panaplex Displays, Below I have included 2 more items:
image    image
