Well the next victim is my LAMBDA LP 411 FM.. This needs the ER.. Picture 1 tells the tale. I need a new meter new binding post (black) I should have that at least. Also the current meter needs both a new lens, and scale the meter itself looks ok. The meter looks like a standard 1.5 inch GE movement (ebay). The current limiter shaft is bent, I don't know if that can be fixed. By looking at the yellow triangle it said 81/82 but the orange tag says: 1972/73.
So what do you know the thing powered up. Man i'm impressed. I have to open it up to fix it. So instead of being asked for interior shots here they are:
| Figure 2 The Guts |
Figure 3 The rear of the front panel dropped. |
Ok lets get to it.
- Bad News for the black binding post... no gots, so I just ordered one on eBay from China.
- It looks like I'm going luck out again. The dam panels bent. Not the pot's shaft! That means an entire tair down of the front panels. There are really two of them. The pretty face and the backer.
- Just as I thought it is a GE meter 18811LCL1AAN. The meter movement is undamaged. Image: 0272.contentimage_4751.png now to just find a donor lens and scale. (Figure 4)
- Stupid me Image: 1185.contentimage_3.png .... remember to unplug the damn thing... I had to reset the breaker, and most likely replace a blown fuse or two.
- Next, let's take the panel apart to straighten the back gray panel (lots of little nuts and bolts) Image: 1057.contentimage_2.png(Figure 5)
- Wow, the back plate is really tweaked (Figure 6), I will have to put this on hold till I can get the panel restored.
| Figure 4 Broken Meter |
Figure 5 Front Panel Disassembled |
Figure 6 Steel Rule across panel Ouch.. |
Shopping List:
- Black Binding Post ... (IN STOCK)
- Meter Lens
- Meter Scale
- Some Fuses... LOL
mcb1
Cancel
Vote Up
+1
Vote Down
Sign in to reply
More
Cancel
phoenixcomm
in reply to mcb1
Cancel
Vote Up
0
Vote Down
Sign in to reply
More
Cancel
jw0752
in reply to phoenixcomm
Cancel
Vote Up
0
Vote Down
Sign in to reply
More
Cancel
phoenixcomm
in reply to jw0752
Cancel
Vote Up
0
Vote Down
Sign in to reply
More
Cancel
jw0752
Cancel
Vote Up
0
Vote Down
Sign in to reply
More
Cancel
Comment-
jw0752
Cancel
Vote Up
0
Vote Down
Sign in to reply
More
Cancel
