NexGen Flight Simuator NexGen: Getting the lab working
  • Author Author: phoenixcomm
  • Date Created: 21 Dec 2014 9:38 PM Date Created
  • Views 1525 views
  • Comments 19 comments
  • Eatontown NJ
  • regatran
  • tr035-0.5
  • old_gear
  • nexgen_flight_simulator
  • electronic Mesurements Co of Red Bank NJ
  • diy_cockpit
phoenixcomm
phoenixcomm
21 Dec 2014
Well here we are now trying to get some power supply working for NexGen. Well I have luging this beast around for more than a few years, and I need some juice for my projects. It seems that my Kepco JQE-6-10 output stage took a dump. image BTW if you have a service manual for this unit please let me know..  I would love to make a copy.image
So... This one was on top of the pile... ok I plugged it in and nothing.. So I checked the fuses and they were both missing so I tossed in the two fuses and bang its... alive. image
Here are the specs:
Manufacture: Electronic Measurements Co of Red Bank  Eatontown, NJ
Model:
Programmable Regatran
TR035-0.5
Serial Number: 3G 4456
Output Voltage: 0 - 36vdc
Output Current: ?
Just a note: If you look at the controls (TL, BR) and the binding posts you will notice that they are bakelite.
This unit BTW if you look at the serial number you will notice the date code: 44 week of 1956 so this unit was built in the last week of October or the first week of November, which makes this power supply is 58 years old! and still works!!
Keep tuned in more to come; image
~~ Cris H.
BTW: at UTA (University at Arlington) we have a maker lab in the Library.. So I can replace the knobs. The only thing that I have to pay for is the nylon.
As Requested:
image image image
Figure 2
Top View
Figure 3
Bottom View
Figure 4
Close Up of the large capacitor.
PS 30Jan2015
I have just inserted picture #4. The Capacitor has a 6-63 date stamp! 2015 -1963 = 52 so about 52 years old...
    e14 Contributor over 11 years ago in reply to phoenixcomm +1
    Hi Cris, Small world... Middletown is my old stomping ground too. MTHS north... a LONG time ago! Yes, Lab-Volt as you've found was a product of Buck Engineering. I'm not sure if Buck is still in business…
    Hi Cris,
    That's not the way the serial numbers work. The 4456 is simply a numerical sequence number.
    The first two digits are a date code. The " 3 " is the year and the " G " is the month.
    In this case, there is some ambiguity, the year could be 1973, but I believe that the Regatran you have is from 19 sixty 3 and the month G is July.
    Hi Cris,
  • phoenixcomm
    phoenixcomm over 11 years ago in reply to e14 Contributor
    Jeff you are right on the date as born out by photo #4 but that is still 52 year old supply that still works... LOL
    I know!  pretty amazing...  E/M made some good stuff back then.  The 'next generation' of these, called the "SCR", "TCR" were just as good.  More power too.  If you ever need lots of power, say 10kW to 15kW, be sure to try and find a used "ESS" series.  Good Luck with your project!
  • phoenixcomm
    Hey Jeff I lived over in freehold for high school but lived in middletown just north of red bank.. lol I believe E/M also had another product called Lab-Volt. they were GE meters and power supplies built into our work bench...image
    PS sorry that was Buck Engineering also a local..
    Hi Cris,
    Yes, Lab-Volt as you've found was a product of Buck Engineering.  I'm not sure if Buck is still in business, but Lab-Volt appears to have been bought by a company called Festo Didactics ...
    They were located over on Rte 34, a bit north of the airport.
  • phoenixcomm
    MGD... I went to Fairview then Thompson then Freshmen (64)  at MTHS near the police station mid way through we moved to Freehold and I went to FRHS!! Do you remember when the Nike Base blew up?? I lived across from the golf range on 35N.  I later went to work for Interdata (76).. down by the racetrack.. after the AF I used to hang out in the Red Bank hobby shop or in Eatontown at Atkinson and Smith. later down the road at the MG dealership. Do you remember the Studebaker showroom in Red Bank...
