NexGen Flight Simuator NexGen: Getting the lab working
  • Author Author: phoenixcomm
  • Date Created: 21 Dec 2014 9:38 PM Date Created
  • Views 1525 views
  • Comments 19 comments
  • Eatontown NJ
  • regatran
  • tr035-0.5
  • old_gear
  • nexgen_flight_simulator
  • electronic Mesurements Co of Red Bank NJ
  • diy_cockpit
phoenixcomm
phoenixcomm
21 Dec 2014
Well here we are now trying to get some power supply working for NexGen. Well I have luging this beast around for more than a few years, and I need some juice for my projects. It seems that my Kepco JQE-6-10 output stage took a dump. image BTW if you have a service manual for this unit please let me know..  I would love to make a copy.image
So... This one was on top of the pile... ok I plugged it in and nothing.. So I checked the fuses and they were both missing so I tossed in the two fuses and bang its... alive. image
Here are the specs:
Manufacture: Electronic Measurements Co of Red Bank  Eatontown, NJ
Model:
Programmable Regatran
TR035-0.5
Serial Number: 3G 4456
Output Voltage: 0 - 36vdc
Output Current: ?
Just a note: If you look at the controls (TL, BR) and the binding posts you will notice that they are bakelite.
This unit BTW if you look at the serial number you will notice the date code: 44 week of 1956 so this unit was built in the last week of October or the first week of November, which makes this power supply is 58 years old! and still works!!
Keep tuned in more to come; image
~~ Cris H.
BTW: at UTA (University at Arlington) we have a maker lab in the Library.. So I can replace the knobs. The only thing that I have to pay for is the nylon.
As Requested:
image image image
Figure 2
Top View
Figure 3
Bottom View
Figure 4
Close Up of the large capacitor.
PS 30Jan2015
I have just inserted picture #4. The Capacitor has a 6-63 date stamp! 2015 -1963 = 52 so about 52 years old...
    e14 Contributor over 11 years ago in reply to phoenixcomm +1
    Hi Cris, Small world... Middletown is my old stomping ground too. MTHS north... a LONG time ago! Yes, Lab-Volt as you've found was a product of Buck Engineering. I'm not sure if Buck is still in business…
    Hi Cris,
    That's not the way the serial numbers work. The 4456 is simply a numerical sequence number.
    The first two digits are a date code. The " 3 " is the year and the " G " is the month.
    In this case, there is some ambiguity, the year could be 1973, but I believe that the Regatran you have is from 19 sixty 3 and the month G is July.
  • phoenixcomm
    phoenixcomm over 11 years ago in reply to jw0752
    What do you think....duh, of course;)  LOL
    jw0752 over 11 years ago in reply to phoenixcomm
    Are you going to try to fix the Kepco?
  • phoenixcomm
    sameo here I was in hs in mid 60's ... lot of good stuff around.. are you interested in Flight Simulation, Linux or Embedded stuff... If you  are go back and read it from the start... enjoy
    Hi Cristina,
    Thanks for the look. It brings back good memories. Did you know that even the solder smelled better in the 50s and 60s. Good to have you as a contact.
