NexGen Flight Simuator NexGen: Instrumentation: Fan Speed N1, GE/Ametek: 8DJ176L
  • Author Author: phoenixcomm
  • Date Created: 27 May 2014 12:26 AM Date Created
  • Views 285 views
  • nexgen
  • aircraft_instruments
  • n1_fan_speed_indicator
  • nexgen_flight_simulator
  • 8dj176l
  • diy_cockpit
phoenixcomm
phoenixcomm
27 May 2014
Indicator, Fan, Speed, N1 - 8DJ176L[ZD2]
image image
Front View
Figure 1
Rear View
Figure 2
Specifications
Size: 2.187"square x 13"long
Mounting: MSP-640003 or eqiv.
Receptacle: MS3113H-18-32P
Mate: DC26F18-32S
PINOUT PINS
Lamps, 4 VAC: A - B
Power Supply, 115 VAC 40 Hz: S - T
Power Supply, 28 VAC: L - M
Reference, 12 VDC: C
Set Index, Return: E
Set Index, Signal: G
Input, Signal #1: D
Return, Signal #1, #2: K
**  Input, Signal, #2: F
**  Output, 28 VDC: a
Output, Analog, #1: H
Return, Analog, #1: J
Output, Analog, #2: V
Return, Analog, #1: X
Switch, Over Limit, #1: R - P
Switch, Over Limit, #2: N - e
Case Ground: U
** Models: 8DJ176LWS2, 8DJ176LZD2
May 2014Copyright  NexGenRegistered C. Harrison
The Ametek Logo belongs to AmetekRegistered
The GE Logo belongs to GERegistered
