NexGen Flight Simuator NexGen: Lab: B&K 3010 Function Generator - Overhual
  • Author Author: phoenixcomm
  • Date Created: 14 Apr 2020 11:07 PM Date Created
  • Views 732 views
  • test equipment
  • b&k precision 3010
  • restorerepairch
  • function generator
phoenixcomm
phoenixcomm
14 Apr 2020
THENimage
NOWimage
Well, I have this unit on the repair shelf for a since 2015/07/22 So after much sawing and filing I got the NEMA socket to fit in the damn hole. In hindsight, I am glad I used the spade lugs! I then use a Molex type plug set with some wire on it so that I can work on the unit while the back is off.
I also replaced the 600ohm solid wire with stranded wires as well.
The 50ohm  cable is not grounded at the circuit board but only at the connector, to reduce ground loops
Good Luck Finding Thisimage
50ohm cable @ PCBimage
FIXEDimage
MOLEX PlUGimage
50ohm cable @ connectorimage
  • michaelkellett
    michaelkellett over 6 years ago
    Just refreshed my memory about this by looking at the schematic you posted nearly 5 years ago.
    It's always nice looking at circuits for stuff of this sort of age because they tend to use ordinary basic components rather than the key functionality being buried in some special chip.
    MK
