NexGen Flight Simuator NexGen: Radio SubSystem: RSS_IOP Part 1 Redux
  • Author Author: phoenixcomm
  • Date Created: 13 Apr 2014 9:52 PM Date Created
  • Views 334 views
  • nexgen
  • c
  • nexgen_flight_simulator
  • diy_cockpit
  • linux
phoenixcomm
phoenixcomm
13 Apr 2014
Ok, it seems that we are back where we started from talking about the RSS_IOP. There have been so many changes that we may as well just start over.image
So now I can share with you the major data structures  from here forward. So lets get started.
rss and tunerradio_xxxxx
typedef enum _Radio_Types {
  G3717,
  C614L8,
  G1981,
  G3490,
  G4214 }Radio_Types;
struct rss_s {
  char * device_info;             // some thing about the radio NAV/COM/etc.
  char * device_model;         // the Manufactures part/model number.
  char * device_serial;          // the device's serial number..
  Radio_Types device_type; // Its device_type which is defined by the typedef above Radio_Types
  int power_48v;                   // power to the unit..
  int power_400hz;
  int panel_lamps;                // turn off or on the Panel Lamps only
  void * radio_info;
  void * tuner;
  int sub_devices;                // how many tuners are in this device.
enum fd_index {
  RD,
  WR,
  FD_pair
typedef enum _tuned_units { // this is for numbers that have the form of nnn.ff (n= number) (f= fractions)
  hundreds,
  tens,
  units,
  tenths,
  hundredths,
  tuned
}tuned_units;
typedef struct tuner_s { // when we talk about 'sub-radios' we are really saying how many tuners are there??
  int power;
  int dial_lamp;
  char * device_name; // OS-name
  int fd[ FD_pair ]; // file descriptors
  int frequency[ tuned_units ];
}tuner;
// This is for the Collins G14L8 Adf head.
typedef enum _mode_sw_614L8 {
  OFF = 0,
  ADF,
  ANT,
  LOOP
}mode_sw614L8;
typedef enum _loop_sw_614L8 {
  LEFT,
  RIGHT,
  SLEW_LEFT,
  SLEW_RIGHT,
}loop_sw614L8;
struct radio_s_614L8 {
loop_sw614L8 loop_sw_614L8;
mode_sw614L8 mode_sw_614L8;
  int sw_band;
  int sw_bfo;
  int meter;
////   G1981 ATC  Transponder
//     As the ATC Transponder does not have a tuner
//     we can ignore the field 'int frequency[ tuned ];'
typedef enum _mode_sw_G1981 {
  STBY,
  ON,
  LOW,
  mode_swG1981
  }mode_sw_G1981;
typedef enum _band_sw_G1981 {
  band_A,
  band_B,
  band_C,
  band_D,
  band_swG1981
  }band_sw_G1981;
struct radio_s_G1981 {
  mode_sw_G1981 mode_switch;
band_sw_G1981 band_switch;
  int sw_ATC;
  int sw_ident;
  int test_monitor;
  int alt_off;
  int squawk[ 4 ];
//// G-3717  this is a simple radio with 2 tuners.
struct radio_s_G3717 {
  int sw_VHF_NAV;
  int sw_VOR_TEST;
  int sw_DME_TEST;
  int sw_DME_STBY;
  int sw_UP;
  int sw_DOWN;
main.c
#include <stdio.h>
#include "rss.h"
#include "main.h"
#include "rss_init.h"
int main(int argc, char *argv[]){
  max_fd = 0;
  int ecode;
  // bus voltages
  int p400;
  int p48;
  // The Radio Tuners
  // ** Please note the "dev/stuff is not right and must be changed before testing.
static struct tuner tuner_G_3717[] = {
  { 0, 0, "/dev/tty0/usb1", },
  { 0, 0, "/dev/tty0/usb1", } };
static struct tuner tuner_C_614L8[] = {
  { 0, 0, "/dev/tty0/usb1", }};
  static struct tuner tuner_G_1981[] = {
static struct tuner tuner_G_4214[] = {
static struct tuner tuner_G_3490[] = {
  // The Radio Details
static struct radio_s_G3713 radio_G_3713  = {
  { 0, 0, 0, 0, 0, 0 }};
  static struct radio_s_614L8 radio_C_614L8 = {
  { 0, 0, 0, 0, 0 }};
  static struct radio_s_G1981 radio_G_1981  = {
  { 0, 0, 0, 0, 0, 0, {0}}};
static struct radio_s_G3490 radio_G_3490  = {
  { 0, 0, 0, 0, 0, 0, 0 }};
  static struct radio_s_G4214 radio_G_4214  = {
  { 0 }};
  // The Radio(s) Master List
  static struct rss_s radios[] = {
  { "COM 1 & 2", "G-4214", "68", G4214,  0, 0, 0, & radio_G_4214,  tuner_G_4214,  DIM( tuner_G_4214 )  },
  { "VOR, DME", "G-3717", "81", G3717,  0, 0, 0, & radio_G_3713,  tuner_G_3713,  DIM( tuner_G_3713 )  },
  { "ADF", "614L8", "8384", C614L8, 0, 0, 0, & radio_C_614L8,  tuner_C_614L8, DIM( tuner_C_614L8 ) },
  { "ATC", "G-1981", "336", G1981,  0, 0, 0, & radio_G_1981,  tuner_G_1981,  DIM( tuner_G_1981 )  },
  { "5in1", "G-3490", "31", G3490,  0, 0, 0, & radio_G_3490,  tuner_G_3490,  DIM( tuner_G_3490 )  }, // Optional Radio
  int i, j;
  // loop over the installed Radios and sub radios
  for( i = 0; i < DIM( radios ); i++ ){
  if( rss_init( & radios[ i ] ) == ERROR ){
  perror( "Initialization failed");
  return( ERROR ); }
  do{
  ecode = 1;
  // test for power errors
    p400 = power_buss_400hz();
    p48 = power__buss_48v();
    if( p48 != OFF || p400 != OFF ){
  ecode = GO;}
  else {
  ecode = ERROR;
  if( !p400 )
  error_msg();
  if( !p48 )
  error_msg();
  // iop returns with error TBD!!
  }  while( ecode != ERROR );
So far so good. I have shown you what our data structures are now.  I will show you my main.c. You will notice that all of the radio components ie: radio[], tuners, and radios are all declared static, as their "lifetime or extent" extends across the entire run of the program.
image Keep tuned in, more to come!
~~ Cris.
Apr 14, 2014
Changes just a few:
1)  struct radio_614L8 is now struct radio_s_614L8
     the radio_s_XXXX is the form that I will be using the _s_ stands for structure
     this changes the invocation of the radio in my main.c
     from
     static struct radio_G3713 radio_G_3713
     to
2) power testing has been simplified:
      if ((( p400 = power_buss_400hz()) || ( p48 = power__buss_48v())) != OFF ){
   to
