NexGen Flight Simuator NexGen: RSS: Radio Set C-3436A/ARN-30D: Interface Cable REDO  FINS!!
  • Author Author: phoenixcomm
  • Date Created: 12 Mar 2021 7:04 PM Date Created
  • Views 749 views
  • flight simulator
  • nexgen
  • diy aircraft cockpit
  • interface cable
  • c-3436a radio set
  • diy electronics
phoenixcomm
phoenixcomm
12 Mar 2021
I have been working on my C-3436A radio for quite a while after it worked I took it apart to install it in its new home and I could never get the damn thing to work again.  So with way too much time on my hands, I decided to ring out the damn cable once and for all.  Now I can report the job is done. KiCad helped me see my mistakes. This cable is really two cables each terminated with DB-25Ms at one end and ARC connectors at the other. One cable was just DB-25M to a 19 pin ARC connector. The other cable also is terminated at one end with the DB-25M but on the other end, there are two (2) eight-pin ARC connectors. The problem I have had with my cable was of my own making. Instead of wiring the DB-35 as top row 1 to 13, and lower row 14 to 25. I wired them in a zig-zag pattern ie 1, 14, 2, 15, 3, 16, etc.image
I hope nobody notices the typo in the schematic. In the title block, I referred to this as a C-3236, and that 2 should have been a 4. image I'm going to fix my Documentation but probably not going to update it here.  ~~Cris
    DAB over 5 years ago +1
    A US Navy study found that 50% of all avionics failures were cable related. Always check your cables. DAB
  • phoenixcomm
    phoenixcomm over 5 years ago in reply to DAB
    DAB This is why I need some sort of Cable Auto Test System image
  • phoenixcomm
