NexGen Flight Simuator NexGen Sim: Converting the Game Port to USB  - Suncom Daul Throttles Quadrant -  Part 3
  • Author Author: phoenixcomm
  • Date Created: 23 Dec 2017 10:46 PM Date Created
  • Views 968 views
  • throttle quadrant
  • nexgen
  • gameport to usb
  • eadin lite
  • hardware
  • diy
  • cockpit
  • software
  • linux
phoenixcomm
phoenixcomm
23 Dec 2017
Well, here I am again so let you all in whats really going on. I need a dual Throttle Quadrant. As I have said before I have 2 of them.
So here is the PLAN:
Now I distrust USB as when it fails you cant trust the configurations anymore.  So I will communicate via RS-485 between Arduinos, with the master node,
using NASA's EADIN Lite Protocol.
having an Ethernet interface, to talk to the simulator. So far I have 3 nodes:
  1. Master: runs joystick and talks to the simulator via ethernet and talks RS-485 to the slaves image
  2. Slave.1: runs Throttle Quadrant, Gear Lever, and Gear Lights
  3. Slave.2: runs Rudder and Brakes
  4. Slave.3: runs Engine Start Panel, Computer Fail-Over Panel
  1. Complete Disassembly.
  2. Toss the Base Cover and bottom, I will keep the upper arc.
  3. Desolder and remove all the wire from the switches, we don't need it.
  4. That should leave you with the following:
    1. The Left Shell Body
    2. The Left Shell Rear
    3. The Right Shell Body
    4. The Right Shell Rear
    5. The Right Switch Support
    6. The Top Cover and Wipers
    7. The 2 Throttle Bodies
    8. Long Bolt & tension arm (nut)
    9. 2 white spacers
    10. 3 wave washers
    11. Quadrant center plate
  5. Now Remove and Toss the stupid lever locks and fill the hole.
  6. I want to replace JS1 and JS2 with analog joysticks
  7. I want to lengthen the Power Lever Arms with some aluminum.
  8. I want to add  "gates to the Power Levers, fuel shutoff, and turbo.
  9. I will most likely rebuild the Quadrant base to add room for gates and thicker arms.
ConnectorPinsFunctionsD/APins
L1Left Multi-Function SwitchPA078
L2Trim Wheel (wiper)ADC889
L3, 4Pinky SwitchPA1 PA2
77
76
L65+ volts
L7Ground
R1, 4
JoyStick 1
Note should convert to an
analog joystick
PB0
PB1
PB2
PB3
19
20
21
22
R5, 8
JoyStick 2
analog joystick
PB4
PB5
PB6
PB7
23
24
25
26
R9, 10Mic Switch
PC0
PC1
53
54
R11, 12Coolie Hat,
PC2
PC3
55
56
R13, 14Boat Switch
PC4
PC5
57
58
R15,16Mode Switch
PC6
PC7
59
60
R205+ volts
R25Ground
C1Right Power LeverADC988
C2Left Power LeverADC1087
C3Right Fuel Switch PG051
C4Left Fuel SwitchPG152
C5Right AB SwitchPG270
C6Left AB SwitchPL035
C75+ volts
C9Ground
G1Landing Gear LeverPL136
G2Gear, NosePL237
G3Gear, Main, RightPL338
G4Gear, Main, LeftPL439
G55+ volts
G6Ground
Series Index:
  • Part 3.  Rebuilding Suncom Dual Throttle Quadrant
  • Part 2.   Convert GamePort Controlers to USB
  • Part 1.  What to do with old GamePort Controlers?
Arduino microcontrollers
communicating with EADIN Lite
protocol for real-time sensing
and actuation.
NASA Techbriefs #23450
    ~ CA Harrison image
    PS. More to come!
    mcb1 over 8 years ago in reply to phoenixcomm +1
    I wonder if NZ still has the Aermaci Simulators sitting in Ohakea. Good catch looks promising.
  • phoenixcomm
    phoenixcomm over 8 years ago in reply to mcb1
    Yes, Eadin lite looks good Im still messing about with paper. I haven't powered it up yet.
    and a boneyard.. I wish. good scrap yards though, this is the biggest catch. PHOENIX2000 Lear Jet
    EADIN looks like a very useful protocol.
    Thanks for sharing it
    You're right about USB and the need to be absolute about what is going on.
    I imagine you'd have an absolute ball at the Aircraft boneyard and bring home home everythign you can. image
    Cheers
