    • Avnet Boards Community
NexGen Flight Simuator NexGen: Tech Tip V. Remove Labels and Adhesives
  • Author Author: phoenixcomm
  • Date Created: 21 Aug 2019 4:49 PM Date Created
  • Views 1699 views
  • Comments 18 comments
  • nexgen
  • tape
  • wd-40
  • label
  • motsenbocker's lift off
  • label remover
  • tech tips
  • and adhesive remover.
  • krudkutter
phoenixcomm
phoenixcomm
21 Aug 2019
Ever try and remove a label from plastic? Yep, WD-40, Goo Gone, and others including yep peanut butter well just don't really work, or damage the plastic that the label is attached to. Most of you have used the old stand by a hair drier as well. But that tends to leave a residue, and you cant use it on PCB boards as its way too hot.image
Well, you got to check this stuff out. Motsenbocker's LIFT OFF Tape, Label, and Adhesive Remover. I have this old Milwaukee too case that had some fool put masking Duck tape on. And I could never get it cleaned up. Squirted a little on the mess and bingo it came off with a scratcher sponge. A little soap and warm water and it looked factory fresh.image
On-line it is about $10, but at Walmart, it is about $6.
UPDATES:
Sorry Fix: not masking tape but Duck Tap!
Added the third and fourth sentences starting with: "Most of you have used the"
    Jan Cumps over 6 years ago +5
    What helps with older labels that have been there for a long time, in particular paper ones: Heat them with a hair drier on a temperature that you normally use to dry your hair. This often makes the glue…
  • colporteur
    colporteur over 6 years ago +4
    OK, I shelled out $ 38.22 Canadian to Amazon on your commentary for 32oz of the label removing elixir. Your pic of the removal products looked like it was taken from the shelf in my garage. I am hoping…
  • colporteur
    colporteur over 5 years ago in reply to phoenixcomm +4
    As I have gotten older or as my patience has gotten shorter, I'm skeptical when I hear the expressions, it's easy or it works. I discover it is easy, if you have a Phd in the subject and it works, provided…
  • colporteur
    OK, I shelled out $38.22 Canadian to Amazon on your commentary for 32oz of the label removing elixir.
    Your pic of the removal products looked like it was taken from the shelf in my garage. I am hoping the product has success on removing the labels on liquor bottles.
    A number of years ago I found, in a computer book store of all places, a book on building ships in a bottle. That book caused me to set sails for a hobby that competes for time with my love of dabbling in technology.
    One of the most arduous tasks is bottle preparation! The fk'n labels on some products never want to give up the bottle without a g.d. fight. A few bottles have gone against the garage wall in frustration. Funny, when I started the hobby I told myself I would have to develop patience in order to self teach myself the skills.
    I am waiting for the box with a smile, to delivers the solution to eliminate the need to patch holes in the drywall on my garage wall.
    I have bookmarked this post to give you an update of the results.
    Sean
  • phoenixcomm
    phoenixcomm over 6 years ago in reply to colporteur
    My G-d 32CD! for the 32 oz bottle, I am using the 22 oz spray bottle I don't buy off Amazon as they are tooo much money
  • phoenixcomm
  • colporteur
    colporteur over 6 years ago in reply to phoenixcomm
    No other place to get it other than shipping to drop box across the boarder in the US. If it works I will look for cheaper.
    I'm skeptical, the liquor labels seem to be put on with a bonding agent used to hold the tiles on the space shuttle.
    Sean
  • phoenixcomm
    LOL!
