NexGen Flight Simuator REVIEW: TEMU Cable Sleeve
  • Author Author: phoenixcomm
  • Date Created: 15 Jan 2024 10:44 PM Date Created
  • Views 3040 views
  • flight simulator
  • nexgen
  • TEMU
  • cable management
  • Cable Sleeve
phoenixcomm
phoenixcomm
15 Jan 2024
imageOk, I have had this for a couple of years now, I don't even know where I got it from mostly from some surplus crud. On Temu this stuff has a bunch of 5-star reviews... The plot thickens, I tried in vain to use this stuff to hold my AC cables behind one of the stereo legs. I have one or two wires from the upper shelf and adding a single wire on every shelf.
To put it simply you can't get there from here! Can't be done nada, zip, zilch. I tried 3 or 4 times before giving up and resorting to cable ties. This stuff only works for straight runs. So for my review, I give it 3 stars begrudgingly, with strong language appended ~~ Cris
    shabaz over 2 years ago +1
    Hi Cris, I've never heard of Temu (except at Xmas time when there was Temu mail every hour in my inbox - Microsoft seemed to have difficulty detecting it was spam). This stuff is pretty good (cheaper…
    beacon_dave over 2 years ago
    I used to use similar stuff a lot for controlling power cables from electrical floor boxes to CPUs and monitors in training rooms. Due to the 'spine' it tends to only curve substantially in one direction (as per the product photo above) so you need to keep that in mind when starting out. Once you've done a few 100 cables though, you start to get the hang of how to tame it Slight smile
    If you want more flex in all directions you probably need to use the older spiral wrap, however it is a lot slower to use.
    DAB over 2 years ago
    I have heard of Temu, but it has been about 50 years since I had to wrap my own cables.
    Back then there was a nice product, I can't remember who made it, that just zipped around the cables and remained flexible so I could run it between rooms.
  • phoenixcomm
    phoenixcomm over 2 years ago in reply to shabaz
     shabaz Yes, I could have used Velcro, but I didn't have any on hand!!  I  can buy the stuff all over. and 3m looks to have the brand. ~~ Cris
    Hi Cris,
    This stuff is pretty good (cheaper than the Temu product, can be cut and used to tie every 30cm or so on the cable.
    I don't know of a source in the USA, but in the UK it's about £18 GBP including tax, for a 15 meter roll. I've been using one roll for years.
    (Also very easy to modify layouts, since it can be untied one place at a time, to add or remove cables. One colleague used this for beautiful network cable layouts, with cables coming off at evenly spaced positions with a perfect 90 degree curve etc : )
    Image source: Startech.com
