NexGen Flight Simuator Soldering School - part 3: The Cable Multi-Purpose Color Display (F/A-18C/D MPCD)
  • Author Author: phoenixcomm
  • Date Created: 24 Sep 2014 3:43 AM Date Created
  • Views 636 views
  • hardware
  • repair
  • nexgen_flight_simulator
  • nasa-std-8739.3
  • soldering
  • nasa-std-8739.4
  • cabling
  • diy_cockpit
  • feature_tutorial
phoenixcomm
phoenixcomm
24 Sep 2014
Well here we are again, I know your going to ask me why am I making a post just for this dam cable???image
The cable that had a short in it.
Figure 1
THE ANALYSIS: As you may know back in February I said "It looks like there was a whisker shorting out the Blue.. GROAN: Ok the fix is painful. I have to cut down the shrink wrap and then the electrical tape and two layers of shrink wrap over the Blue itself." So being lazy I did repair the cable by opening the green layer and then re-soldered the blue but I "rigged it" LOL. At the end of August, I went to Cockpit Fest with the Cable as you guessed I never fixed the *** Cable, so its time to do something about it..  I really want this to be a pro. so I just cut the cable in half time to start over and just do it right.
THE PLAN:
  1. Cut the cable in twain and re-strip the wires. Please see Figure 3 for the proper tools.
  2. Obtain the proper solder splice (see Figure 2).  They can be found on eBay with the search term "solder sleeve".  You will notice that it is a heat shrink tube with solder in it. Here is a nice little video that demonstrates the proper technique for applying the but splice. (Video below). Please see NASA-STD-8739.4 March 2011 page 83 #19.8
  3. First, we have to slide a new piece of shrink wrap on the cable.  This will be used as the outer sheath.
  4. We will also side a piece of shrink wrap on each one of the Red, Green, and Blue.
    1. Now use the solder sleeves to solder the three (3) drive wires  (coax centers).
    2. Now solder the three (3) shields (don't need but splices).
    3. Now install the  yellow  shrink tubing  over the shields
  5. Now use the solder sleeves to solder the two (2) sync lines together.
  6. Also, solder any other remaining wires as per Table 1.
  7. shrink any tubing over the other connections.'
  8. Pull into place the outer shrink tube and shrink it.
Solder Sleeve
Figure 2
Keep Tuned in.. More To Come!
image  Cris
Signals PS3 Cable VGA Cable
RED RED RED
GREEN GREEN YELLOW
BLUE BLUE BLUE
SYNC blue Tan
SYNC red red
Yellow
white
Black
Black
Green
Blue
Black
Orange
Soldering Guide
Table 1
Mechanical Stripper Thermal Strippers
image image
Wire Strippers
Figure 3
References:
  • NASA-STD-8739.3  Feb 1998  Soldered Electrical Connections
  • NASA-STD-8739.4  Feb 1998  Crimping, Interconnecting Cables, Harnesses, and Wiring.
  • NASA-STD-8739.4  Mar 2011  Crimping, Interconnecting Cables, Harnesses, and Wiring
  • NASA Training Program          Student Workbook for Hand Soldering
I will be posting pics of the steps here...
The Cable
Photos
PS3 cableimage
(1-3)
VGA cableimage
(3-4)
Cable trim is too shortimage
Proper installation of solder sleeve
(4.1, 4.2)
Shrink tube over the solder sleeve and shield
(4.3)
Groundsimage
(8,9)
Pulling the outer sleeve over the wire splices
(sorry for the blurry pic)
(10)
  • phoenixcomm
    phoenixcomm over 12 years ago in reply to shabaz
    thanks, look at the student guide for more of the how to guide... The STDs are the Bible
    shabaz over 12 years ago
    Hi Cris,
    Thanks to the link to the document, this looks great - looking forward to going through it. There is clearly decades of experience in there, so well worth studying.
    DAB over 12 years ago
    Hi Chris,
    Good post.
    I would add here that 50% of avionics failures are due to cable issues.
    Between a bad wire in a cable, the wrong cable connected to the wrong box, and just loose cable connections, well you get the picture.
    The best device in the world cannot work if its not plugged in properly.
    So I am glad that you emphasized the cable issue.  It bites nearly every project at one point or another.
