NexGen Flight Simuator What You Can Get Away with on Television: ZYRTEC Barcode Beat Conductor Commercial
  • Author Author: phoenixcomm
  • Date Created: 25 Jan 2024 7:12 PM Date Created
  • Views 1937 views
  • Comments 11 comments
  • what you can get away with on television
  • ZYRTEC Barcode Beat Conductor Commercial
phoenixcomm
phoenixcomm
25 Jan 2024
For giggles, I figured I would add this commercial to my little hall of shame! What happens is impossible, as the scanner is mono-tonal, not multi-tonal.  See about 10 seconds in.
  • javagoza
    javagoza over 2 years ago
    Most Barcode scanners usually have a beep on successful transmission and a beep at decode time both with different frequencies although sometimes can be disabled. Usually, you can program the scanner with a barcode selecting Low Frequency, Medium Frequency, or High Frequency for the two different tones. So maybe you can get up to 6 different tones Stuck out tongue
    When working with NFC card readers for payments, the reader uses two tones, the success tone and the alert tone.
    The success tone usually is a single long beep and the alert tone is usually a double short beep with lower frequency.
    One typical setup, recommended by VISA,  is:
    • Success tone: single beep with a frequency of approximately 1500 Hertz, sine wave shape, and duration of approximately 500 ms
    • Alert tone: a double beep with a frequency of approximately 750 Hertz, sine wave shape. Each beep shall have a duration of approximately 200 ms with a gap between the two ‘beeps’ of approximately 200 ms
  • javagoza
  • phoenixcomm
    phoenixcomm over 2 years ago in reply to javagoza
     javagoza OK, maybe so, I think  dougw  was right though! ~~ Cris
  • javagoza
    javagoza over 2 years ago in reply to phoenixcomm
    Me too. I'm just kidding
    beacon_dave over 2 years ago in reply to javagoza
    I was awaiting the video...  Slight smile
  • phoenixcomm
    phoenixcomm over 2 years ago in reply to beacon_dave
     beacon_dave The video works, just click the little arrow..   ~~ Cris
    beacon_dave over 2 years ago in reply to phoenixcomm
    I was referring to a follow-up spoof video showing javagoza with a VISA recommended two-tone performance. Slight smile
