Nico teWinkel's Blog Gobetwino with Open Office
  • Author Author: ntewinkel
  • Date Created: 26 Mar 2012 9:07 PM Date Created
  • Views 539 views
  • spreadsheet
  • gobetwino
  • excel
  • open
  • logging
  • office
  • data
ntewinkel
ntewinkel
26 Mar 2012
neilk gave me the idea of logging greenhouse temperature data into a spreadsheet, so I did a little more investigating into how this would work with Gobetwino. I have a little greenhouse not too far from the house, so I thought this might be a neat thing to try with the use of a wireless connection - maybe Bluetooth or using those inexpensive nrf24l01 cards.
I'm using WindowsXP and openOffice.org 3.3.0. It shouldn't make a difference, but this is all within a VirtualBox VM on a Mac.
As it turns out, the basics are not too difficult: I was able to fill in data and navigate fields, but I wasn't able to get it to insert a timestamp into a field.
I've attached the sketch to do this. On the Gobetwino side you will need to set up a new Command with the name "OPENOFFICE" and the path "C:\Program Files\OpenOffice.org 3\program\scalc.exe" (do not enter the quote marks for either case).
As you can see, this sketch does nothing more than test the possibility of data logging using Gobetwino - I haven't done any data sampling or wireless communications yet.
I did also try it on a Vista machine, but Gobetwino reports the application closing, which then means it refuses to talk to it after that.
Thanks for the inspiration, Neil!
Cheers,
-Nico
In easy text, this is what the series of commands looks like:
void setup()
   Serial.begin(9600);
   //Serial.println("#S|NOTEPAD|[]#");
   Serial.println("#S|OPENOFFICE|[]#");
   //delay(10000); // wait for OO to start up
   Serial.read(); // gobetwino returns the processID when it has started up.
   // set up the header line
   Serial.println("#S|SENDK|[0&Time]#"); // column 1 = timestamp
   Serial.println("#S|SENDK|[0&{tab}]#"); // tab to go to next column
   Serial.println("#S|SENDK|[0&Greenhouse Temp]#"); // column 2 = inside temp
   Serial.println("#S|SENDK|[0&Outside Temp]#"); // column 3 = outside temp
   Serial.println("#S|SENDK|[0&{enter}]#"); // enter to go to next line
   Serial.println("#S|SENDK|[0&3:45am]#"); // fake a time
   Serial.println("#S|T|[]#"); // time stamp
   Serial.println("#S|SENDK|[0&10.0 C]#"); // fake a temperature
   Serial.println("#S|SENDK|[0&2.5 C]#"); // fake a temperature
gobetwino.ino.zip
  • neilk
    neilk over 14 years ago +1
    Hi Nico I've been playing a bit with Gobetwino and finally cracked the T (TimeStamp) and, implicitly, the D (DateStamp) command. Have a look at my blog. All the best Neil
  • neilk
    Hi Nico
    All the best
    Neil
  • neilk
    Hi Nico
    All the best
    Neil
