    • Avnet Boards Community
Nico teWinkel's Blog Nail Polish Short-proofing?
  • Author Author: ntewinkel
  • Date Created: 26 May 2018 11:57 PM Date Created
  • Views 3549 views
  • Likes 10 likes
  • Comments 18 comments
  • nail polish
  • conformal
  • heat_shrink_tube
  • conformal coating
ntewinkel
ntewinkel
26 May 2018
Hi all,
I just kind of randomly came across a thread discussing using nail polish to cover electrical connections to avoid shorts, especially for the backs of home made PCBs.
There are commercially available "conformal coatings" you can use, but they are somewhat more pricey, and I guess a fair bit more boring image
So I went to the dollar store yesterday and picked me up some of this!
Only $1.50 (Canadian dollars even!)
I was thinking I might use it on a past or future PCB to coat the back.
This is the first time I've ever bought nail polish, which I think explains the conservative colours image
It says "Kozmic Colours", so just imagine the variety available! I thought I'd avoid the sparkly ones though, as I wasn't sure if that might be conductive.
Then today I soldered a light resistor onto some wires, and then wished I had remembered to put on some heat shrink tubes. The shrink tubes were aaaalll the way in the workshop and I was being lazy image
Then I realized I could probably use the nail polish for this!
It looks like it does the trick - as you can see in the pictures, it has fully coated the exposed wires. It's easier than dealing with heat shrink tubing, and can be added as an afterthought. It's not as rugged as heat shrink tubing, but for many of these smaller light-duty cases it's perfect.
Next time - red and black!
Cheers,
-Nico
edit: I just did a quick resistance test, and I can clip the test leads right beside each other on a (coated) pin of the sensor with full resistance.
    jw0752 over 7 years ago +5
    Hi Nico, I would be interested in learning more about its insulation value. I am sure you could increase the insulation value by putting multiple coats on it. If smell is any indication it should be pretty…
    mcb1 over 7 years ago +4
    This is the first time I've ever bought nail polish Are you sure .... For higher power/mains systems I can't see it meeting any sort of voltage rating, but for low voltage, if it gets you out of a problem…
    mcb1 over 7 years ago in reply to jw0752 +4
    I'm starting to get worried now that you boys are becoming proficient in buying and using nail polish. The proper coatings might be a worthwhile roadtest. What do you think rscasny ( about the road test…
    shabaz over 7 years ago
    Hi Nico!
    Nice quick solution : )  Smells nice while it is drying too : )
    For higher power/mains systems it may be risky, as I understand it contains flammable stuff? I'm no chemist though : ) Maybe it is non-flammable when dry, since so many people stick it on their nails : )
    Good to see this idea for providing insulation. I wonder what other fast-drying paint-on coatings are easily available too.
    Hi Nico!
  • ntewinkel
    ntewinkel over 7 years ago in reply to shabaz
    I was expecting it to be a lot more toxic smelling, but it didn't really have much of a smell... maybe the solder flux was still numbing my senses image
    Right, personally I'd avoid it for anything other than the low voltage USB or lower projects, as it seems to be a kind of soft coating (judging by the many chips and scrapes the ladies get on them).
    I'm pretty sure the fumes the wet stuff gives off will burn. I might have to test flammability of the dry stuff, now that you brought it up, and it has nothing to do with my pyromaniac issues image
    But yes, it's not often we see smokers have their nail coatings catch on fire image  You'd think that would be a great incentive to stop, but then again the danger factor might be another incentive for them to start. image
    Good question. It's amazing actually how often inexpensive easy-to-find everyday items can come in handy for our projects!
    This stuff comes to mind: Plasti DipRegistered Liquid | Canadian Tire
    It's a thick rubberized coating sort of thing. It's $25, but that's a huge amount of it.
    -Nico
  • ntewinkel
    ntewinkel over 7 years ago in reply to ntewinkel
    Ok I smell it today. yikes how did I not notice that last time! Smells like flammable VOCs for sure image
