Nico teWinkel's Blog Sometimes it's not actually a glitch.
  • Author Author: ntewinkel
  • Date Created: 1 Dec 2020 1:57 AM Date Created
  • Views 1492 views
  • Likes 9 likes
  • Comments 14 comments
  • hummingbird
  • usb heater
  • feeder
  • wemos d1 mini
  • temperature
  • esp8266
ntewinkel
ntewinkel
1 Dec 2020
Have you ever had one of those moments where the data just looks out of place?
The above chart is from 2 temperature sensors. The one shown in green is connected to my hummingbird feeder (insulated, with a small USB-powered hand-warmer heater on it), and the other is hanging under the eaves to allow me to compare heater performance to outdoor temperature. It's set up using 2 Wemos D1 Minis with a few PHP scripts on the server side. It was a quick independent solution to get some quick data for my hummingbird feeder heater projects, so I expected some issues.
And the graph shows a sudden 3 degrees C dip in just 15 minutes from approximately 6:44 am to 7:02am!
In my case the above sort of graph glitch usually leads to digging a bit deeper and fixing some bugs. I thought maybe the power or WiFi was out for a bit, but the points actually show the gradual decline.
However, this time around it seems the weather had a glitch, not my project!
The last 24 hours of data from our weather office shows a sudden dip in temperature too (2.5 degrees C), along with a shift in wind direction (SE to NNW) and clearing up (as seen in the visibility and conditions columns). Their data only shows the rougher hourly increments, compared to my by-the-minute reports.
Interesting, to me anyway image
Also interesting and useful to me is the fact that the hummingbird feeder dropped rapidly in temperature too, even though it is insulated and heated... it's possible the heater didn't kick in during that time, or maybe I need a more powerful heater and better insulation.
I bought this little USB powered cup warmer for my next heater to try. Canadian Tire, for $15 CAD - that's about 1/3 the cost of a purpose-built hummingbird feeder heater. Seems expensive for a cup warmer, and probably not very effective for that purpose (just buy an insulated travel mug!), but it appears to be perfect for keeping hummingbird feeders frost-free in my climate!
Hope everyone is doing well and staying warm and safe out there!
Best,
-Nico
  • Gough Lui
    Gough Lui over 5 years ago +6
    We recently had a heatwave over Saturday/Sunday reaching 40+C. But a quick change of the winds caused a massive drop in temperature here too: Reality sometimes can surprise you! - Gough
  • colporteur
    colporteur over 5 years ago +4
    I'm surprised the birds stick around. Hummers usually leave early in our climate.
  • neilk
    neilk over 5 years ago +4
    Nice piece of analysis, Nico. I presume you have updated your graphing software to the new(ish) Google standards?? Mine stopped working a while ago and although I've looked at the new standards, I haven…
  • neilk
    Mine stopped working a while ago and although I've looked at the new standards, I haven't got around to changing my code. Hence no graphics, just inspection of the files image
    Neil
  • neilk
    Neil
  • ntewinkel
    ntewinkel over 5 years ago in reply to neilk
    Hi Neil!
    I was thinking of you as I was fixing the graphs LOL.
    I gave up on the Google charts and now use Chart.js instead and store the library locally so it doesn't get broken on someone else's whim.
    The html file is a bit of a hack to get the 2 sensors into one graph - the first log file provides the time stamps, the second log file is assumed to be using the same time. In reality that just means I have to plug in the 2 sensors at roughly the same time, and delete the log files to synchronize them.
    I can pop the updated files onto Drive or Dropbox for you.
    -Nico
  • neilk
    neilk over 5 years ago in reply to ntewinkel
    Hi Nico
    I have sort of been looking around for an alternative to Google charts as well, but hadn't considered charts.js.
    I would appreciate a look at your files and maybe some assistance in getting charts.js installed on my server.
    Drive is probably the easiest for me.
    Thanks
    Neil
  • ntewinkel
    Hi Neil,
    I've sent you a PM with the info.
    There's nothing to install - just copy the javascript files onto the webserver in the same place as the html and php files.
    Best,
    -Nico
  • neilk
    Hi Nico
    Done
    Many thanks
    Neil
