Ralph Yamamoto's Blog AnyCubic Mega-S - Prime Day
  • Author Author: ralphjy
  • Date Created: 20 Jul 2019 8:28 PM Date Created
  • Views 2226 views
  • Comments 20 comments
  • 3d printers
  • velleman k8200
  • anycubic
ralphjy
ralphjy
20 Jul 2019
After a fair amount of frustration trying to fix the hotend/extruder on my Velleman K8200 3D printer I finally decided that I should just go ahead and buy a new printer.  I really like the K8200, it has a large build area (20 x 20 x 20 cm) and has worked reliably for 6 years.  But recently I've been having lots of problems with it.  I think it started with some bad filament.  I kept getting jams in the Delrin isolator in the extruder due to expanded filament.  I replaced the isolator but that only helped a little and then I ended up with a clogged nozzle that I couldn't manage to clear.  So, I bought a new nozzle assembly and when I tried to replace the old one I realized that filament had oozed out onto the heater and created quite a mess.  I debated whether or not to buy an upgraded extruder assembly and to fix my z-axis mechanism which was wearing out.  Decided that I should look for a new printer instead.
I was debating whether or not it was worth it to buy a fully enclosed unit with auto-leveling.  I found that units with an equivalent build area to the K8200 were quite expensive and some used proprietary filament and/or software.  Then along came Amazon Prime Day and I saw the AnyCubic Mega-S printer for under $300 with Prime delivery.   I was a little concerned about such a low cost Chinese printer but the reviews were generally good, so I went ahead and bought it.
Here's the new printer next to the K8200.  It actually has a slightly bigger build area (21 x 21 x 20.5 cm) but has a smaller footprint and is about 15 cm shorter.
The major complaint that I've seen about this printer is that it is very noisy.  It also has loud fans in the base for the electronics.  Here's a short clip showing how noisy it is.
Here's the test print of the owl pair.  I'm satisfied with the print quality.  One concern that I have is that I now have a new tool flow.  I used to use Repetier software with a Slic3r slicer.  The recommended tool for this printer is Cura which should be fine although I haven't used it so may have a learning curve.
One feature that I really like is the Ultrabase bed.  It has stippled glass with a special coating that improves print adhesion when it's hot and print release when it is cools down.  Seems to work really well.  The bed has a little warp (higher in the center), so I'm not sure how well it will do with maximum size prints.
I'm currently using the SD card interface to print.  I'll be testing the USB interface with my Mac Mini shortly.  I'd like to use a Raspberry Pi with Octoprint but I've seen some reports of problems on the forums.  I'll try it after verifying the USB interface is working reliably.
The good news and hopefully not the bad news is that this printer came with a lot of extra stuff.
  1. 1kg spool of white filament
  2. 5 x 10m of different color filament samples (red, blue, green, yellow, beige)
  3. Spare print head assembly with filament tube
  4. 5 spare nozzles (0.4, 0.5, 0.6, 0.7, 0.8 mm)
  5. Spare limit switch
  6. Filament cutter
  7. Tweezers
  8. Toolkit (hex wrenches, open end wrenches, screwdriver)
  9. Nozzle cleaning rods
  10. SD card (with test print and software)
  11. USB SD card reader
  12. USB cable
  13. Print removal spatula
  14. Pair of latex gloves
Just hope it doesn't imply a lot of repair image
    genebren over 5 years ago +5
    I am in the market for a replacement printer (mine broke ). I have been looking at the AnyCubic 4MAX Pro 2.0 (quiet box). I am impressed in some of things that I am seeing on the descriptions, like the…
  • ralphjy
    ralphjy over 5 years ago in reply to neilk +4
    Hi Neil, The Mega-S has been (still is) a great utility printer. I use it on a weekly basis and it has held up well. I mainly use it to print holders, cases or adapters for my projects, so nothing fancy…
    dougw over 5 years ago in reply to ralphjy +4
    I have had my i3Mega for years and printed many hundreds of objects (all with PLA). I have never even had to level the bed. The bed surface is awesome at sticking when hot and releasing when it cools off…
  • neilk
    neilk over 5 years ago
    Hi Ralph
    Just catching up in my progress towards committing to a 3D printer!!!
    How has this performed since July 2019 ?
    Neil
  • ralphjy
    ralphjy over 7 years ago in reply to DAB
    I share your concern.  The printer is working well now, but I do worry if the lower cost will translate to poor reliability or longevity.  I can live with the noise level but hopefully that does not mean that there are lower quality components that will fail early.  I'll definitely post if I have good or bad experiences with this printer.  You'll probably be able to tell right away whether I continue to have a lot of printed parts in my projects image
    Ralph
    DAB over 7 years ago
    Nice post.
    I am always leery of a low cost printer.
    I look forward to seeing how well it works out over time.
  • ralphjy
    ralphjy over 7 years ago in reply to genebren
    Hi Gene,
    I found that having a 3D printer really improved my productivity.  You don’t realize how much you rely on a tool until it’s not available.  When my first printer stopped working it really messed up progress on some of my projects.  I worry that I might depend on that capability too much.  But on the other hand it is great fun to be able to create stuff on the fly.
    Ralph
    genebren over 7 years ago
    Ralph,
    Nice write-up/review on your new printer.  It is really interesting to hear what is working or not working with other 3D printers.
    Having a 3D printer has been one of the most interesting new additions to my tool set and work flow.  It is so handy to be able to design/build parts for prototyping designs.  I had heard so many horror stories from early adopters that I was scared off from trying a 3D printer.  It wasn't until reading success stories here on element14 that I decided maybe there is a future for 3D printers in my shop.
    Thanks,
    Gene
