Ralph Yamamoto's Blog Harvesting Mason Bees in Oregon 2026
  • Author Author: ralphjy
  • Date Created: 8 Nov 2026 10:59 PM Date Created
  • Views 158 views
  • Likes 11 likes
  • Comments 7 comments
  • mason bees
  • houdini flies
ralphjy
ralphjy
8 Nov 2026
In order to advance my efforts in the stewardship of local pollinators, I attended a class on harvesting Mason Bee cocoons yesterday that was led by a local Mason Bee expert.
Last year I lost the cocoons from the few nesting tubes that had been filled due to Mono Wasps that penetrated the end mud caps and laid their eggs in the Mason Bee cocoons.  Lesson learned - do not leave the nesting tubes out during the summer unprotected.  The Mono Wasp is much smaller than a Mason Bee and I never noticed them.
I have been hearing about serious issues in our area with another predator, the Houdini Fly, but I've never experienced them.  The Houdini Fly originated in Europe (also a large problem for Mason Bees in the UK).  In 2011, they were detected in New York and by 2020 there were also found in the Seattle, Washington area north of Oregon where I live.  Here is an interesting video about Houdini Fly research being done in Oregon.  Kind of a jump up is that samples taken in Oregon in 2023 had 1 in 10 Mason Bee larvae affected by the Houdini Fly and in 2025 it was 1 in 3.
The Houdini Fly like the Mono Wasp is much smaller that a Mason Bee.
I had never seen these Houdini Fly larvae before, but during this harvesting class - almost every tube that I opened was infested with them.  Interesting thing is that the Houdini Fly eggs are laid in the pollen ball where the Mason Bee also lays its egg.  The pollen ball is the food that the bee larva uses as food when it "hatches".  The fly larvae emerge earlier and in large numbers and consume the pollen ball so that the bee larva basically starves to death.
Here's a picture of one of the tubes that I opened.
When my wife and I harvested the bee cocoons from our backyard bee houses, we didn't find any Houdini Fly larvae - so maybe we have just been lucky.
Here is a female cocoon in the back end of a tube (male eggs are deposited in the front and they emerge earlier).
We do wash the cocoons in a solution of bleach and soapy water to stop other parasites like pollen mites and chalkbrood.
Most interesting discovery was that I found an empty cocoon that appeared a bee had been in it, but it was in an intact tube - and no sign of a bee.
Anyway, I've been thinking about anything I could do proactively to detect these predators next season.  I don't think that I could develop a vision model that could accurately identify these small flies.  I'm definitely going to deploy Malbec traps - the leftover Malbec certainly won't be wasted Joy.
    beacon_dave 19 days ago in reply to ralphjy
    If you initially can detect bee activity at one of the tubes, then you could perhaps stick with that one tube for a while as there will be a good chance the bee will be back-and-forth several times until the tube is full and plugged off. If there are Houdini Flies about, then chances are they will try and target that active tube as soon as the bee leaves. So you have narrowed down the area for closer observation considerably.
    This just does observation however and doesn't really help the bee.
    For the fine mesh idea, I was wondering if you could create a false front for the bee hotel, that was made out of fine mesh with something like sticky fruit fly paper inside. The Houdini Fly when waiting at the sides for the bee to leave might then end up in the sticky trap. That allows for both observation and also helps the bee.
    As the flies are so small, could some sort of vacuum or electrostatic technique be used to grab them if they were to land close enough to the mesh ?
  • ralphjy
    ralphjy 19 days ago in reply to beacon_dave
    I was thinking about trying to detect them in case the trap wasn’t working, but it would be nice to get some closeups.  I will definitely try out your ideas.
    Maybe I could also try to focus on tubes where I detect Mason Bee activity.  Just have to get lucky.  In the video they pointed out that by artificially creating habitat for the Mason Bees we have also caused a growth in the predator population.
    I may have to do a lot of wine sampling Smile.  I think that Oregon Pinot Noir might not be full-bodied enough.  I wonder if a Port might work.
    So, have you signed up for the wine-tasting class yet ?  Slight smile
       "this research is tough... slurp! slurp!"
    The significant size difference is why I suggested the fine mesh, as the flies are so much smaller so will get through into a trap whereas the bees won't. Use the size difference to your advantage.
    If you can reduce the size of the target area, then you might be able to use a low cost USB microscope as the camera, so as to fill the frame with more fly pixels.
  • ralphjy
    ralphjy 20 days ago in reply to beacon_dave
    I’m just hoping the Malbec works.  I can put out a sampler of reds to see if something will work better, maybe a Pinot Noir.
    I definitely would need a better camera to do training and detection.  The red eyes are very distinct, but these are flies are very small.  That picture that I got from the cloud is somewhat deceptive - in the video I linked -> they are much smaller than the Mason Bees.
    beacon_dave 20 days ago
    They are going to be landing near to the front of the nesting tubes as they need to observe the Mason bee leaving the tube to do their deed, so that perhaps narrows down where you might need to point your camera(s).
    Bait traps with a fine mesh covering over them might be another way to encourage them to pose for you in-front of a close-up camera, which you could then use for machine vision.
