Ralph Yamamoto's Blog How to Repair a Kindle Fire HDX Due to Battery Bulging
  • Author Author: ralphjy
  • Date Created: 20 Sep 2022 5:24 AM Date Created
  • Views 3237 views
  • Likes 11 likes
  • Comments 8 comments
  • kindle fire hdx
  • amazon kindle
  • swollen battery
ralphjy
ralphjy
20 Sep 2022
I bought a 7" Amazon Kindle Fire HDX when it first came out in November 2013.  It's claim to fame was its high resolution 1920x1200 color display.  I've been using it pretty much daily since then for an hour or two for videos and puzzles.  Recently I've noticed the back of the case bulging and this morning I saw that the screen had started to separate from the case.
The unit itself is still working, but I think the mechanical stress will probably damage it soon.  I'm going to stop using it until I figure out whether I want to try installing a new battery.  I saw a video on YouTube that made the battery replacement look super simple, but I realized that it was for an HD unit not an HDX.  The HDX disassembly is quite a bit more complex.
All the replacement batteries that I've seen are made in China, I haven't figured out a good source.
Here's one from Walmart for $18.59 (ships from California)
And one from batteryship.com in Wyoming for $35.60.  This one has positive reviews and also comes with tools.  Looks like the same battery that is sold on Amazon.
https://www.batteryship.com/htmlos/htmlos.cgi/batteryship/catalog.html?item=58-000043&model=Kindle+Fire+HDX+7+2013
Or I can buy one from Amazon for under $30 (Chinese brands, no tools, not Prime).
I guess I shouldn't complain as the tablet has worked well for 9 years.  I will probably try to fix it as I like the high resolution display which isn't available anymore.  The current resolution on the 7" and 8" Fire HD tablets is 1280x800.
I'll try to document the repair when I get around to doing it.
  • kmikemoo
    kmikemoo over 4 years ago
    ralphjy  I wanted to try replacing the USB jack on one of my Kindle Fires.  I now have a new Kindle Fire.  I should have paid the $40 plus shipping and let somebody with more patience than I do it.  If the battery is glued to the screen, let someone else do it.  If it is not... go for it.
  • kmikemoo
  • ralphjy
    ralphjy over 4 years ago in reply to kmikemoo
    Hi kmikemoo, I looked at a replacement guide on www.ifixit.com and see why the battery replacement is so difficult - the tablet motherboard is mounted over the battery connector, so it has to be removed to disconnect the battery.  That involves removing a bunch of Torx screws and a few other connectors (camera and a couple of antennas).  It also seems that the battery IS glued to screen frame.  I think they figured out this was a terrible design if you needed to replace the battery.  I watched a video of repairing a 7" Fire HD battery - it was designed later, and you just pull off the back case (case is glued together) and the connector is exposed and the battery held in with mylar tape.  So that repair appears trivial by comparison.
    I think I'll probably try it anyway.  I'm going to make sure it comes apart cleanly before investing in a new battery  I'm hoping that the bulging battery may have already partially separated it from the screen frame.  Just need to figure out where I put my phone/tablet disassembly tools Confused.
