Ralph Yamamoto's Blog How to Repair a Kindle Fire HDX Due to Battery Bulging
  • Author Author: ralphjy
  • Date Created: 20 Sep 2022 5:24 AM Date Created
  • Views 3237 views
  • Likes 11 likes
  • Comments 8 comments
  • kindle fire hdx
  • amazon kindle
  • swollen battery
ralphjy
ralphjy
20 Sep 2022
I bought a 7" Amazon Kindle Fire HDX when it first came out in November 2013.  It's claim to fame was its high resolution 1920x1200 color display.  I've been using it pretty much daily since then for an hour or two for videos and puzzles.  Recently I've noticed the back of the case bulging and this morning I saw that the screen had started to separate from the case.
The unit itself is still working, but I think the mechanical stress will probably damage it soon.  I'm going to stop using it until I figure out whether I want to try installing a new battery.  I saw a video on YouTube that made the battery replacement look super simple, but I realized that it was for an HD unit not an HDX.  The HDX disassembly is quite a bit more complex.
All the replacement batteries that I've seen are made in China, I haven't figured out a good source.
Here's one from Walmart for $18.59 (ships from California)
And one from batteryship.com in Wyoming for $35.60.  This one has positive reviews and also comes with tools.  Looks like the same battery that is sold on Amazon.
https://www.batteryship.com/htmlos/htmlos.cgi/batteryship/catalog.html?item=58-000043&model=Kindle+Fire+HDX+7+2013
Or I can buy one from Amazon for under $30 (Chinese brands, no tools, not Prime).
I guess I shouldn't complain as the tablet has worked well for 9 years.  I will probably try to fix it as I like the high resolution display which isn't available anymore.  The current resolution on the 7" and 8" Fire HD tablets is 1280x800.
I'll try to document the repair when I get around to doing it.
    dougw over 4 years ago
    I had an iphone that bulged like that for a year before the battery was successfully replaced by one of my associates. If you can find a battery, obviously replacing it as soon as possible minimizes risk of catastrophic damage. My Kobo is not bulging, but the battery is not holding a charge for long. I will replace it at some point. There are good Youtube videos on how to replace a Kobo battery and the iphone battery, so you may find a video for your device.
  • rsjawale24
    rsjawale24 over 4 years ago
    Do not keep it inside the device for long. Get it changed as soon as possible it might expand further and crack the screen or explode. Better to replace it at the earliest
  • Andrew J
    Andrew J over 4 years ago
    I had this happen to a MacBook Pro I owned (not the case separation). Once it got in this state I wondered whether it would further deteriorate under use or only under charging - I.e. how safe it was once that process started.  Notwithstanding, I got it changed: a user consumable part that to change requires Apple to have it for 7 days and change the bottom case, keyboard and trackpad as well because of how it is constructed   I’ve become really disenchanted with manufacturers who don’t allow an easy battery swap but it seems that it is very common these days. What a (load of e-) waste.
    Good luck on the fix!
