Ralph Yamamoto's Blog OpenVINO on RPi4 Update
  • Author Author: ralphjy
  • Date Created: 31 May 2020 12:32 AM Date Created
  • Views 537 views
  • rpi4
  • openvino
  • intel movidius ncs 2
ralphjy
ralphjy
31 May 2020
Just a quick update.
I found the problem .  It was not an installation issue per se, but a model mismatch issue.  A problem with pre-compiled model versions and OpenVINO versions.  It is documented here: https://github.com/openvinotoolkit/openvino/issues/411 .  Unless I want to start building my own OpenVINO versions I guess I'll just have to wait until someone fixes it.
The workaround is to revert to earlier models and everything works as expected -> can use different image types and output occurs in the run directory.
Here are the commands to get the old models (I deleted the new ones):
  • wget --no-check-certificate https://download.01.org/opencv/2019/open_model_zoo/R1/models_bin/face-detection-adas-0001/FP16/face-detection-adas-0001.bin
  • wget --no-check-certificate https://download.01.org/opencv/2019/open_model_zoo/R1/models_bin/face-detection-adas-0001/FP16/face-detection-adas-0001.xml
Here is the program output:
And here is the face detect output image:
I'll probably discover a bunch of issues like this as I play around more but hopefully there won't be any specific to differences between the NCS and NCS 2.  Looks like the delivery of the NCS 2 will be on Tuesday.
