Ralph Yamamoto's Blog Tello Drone - Camera Mirror Modification
  • Author Author: ralphjy
  • Date Created: 2 Sep 2018 10:40 PM Date Created
  • Views 2331 views
  • tello
  • drone
ralphjy
ralphjy
2 Sep 2018
One of the limitations of the Tello is the fixed position of its camera.  The camera points forward with a slight down angle which is great for FPV and taking pictures of what is directly in front of the drone.  Some other inexpensive drones that are used for photography have a single axis gimbal that allows you to change the pitch of the camera through about 90 degrees downward.  One application that I have for my Tello is to do inspection of my gutters and solar panels.  For those purposes it would be nice to have a downward looking camera.  I've seen articles on the Internet about adding a downward facing mirror in front of the camera so I thought I would give that a try.
Tello forward facing camera
I found a 3D print design on Thingiverse https://www.thingiverse.com/thing:2911427, but it didn't work well for me and also he had cut an 18mm square from a plastic mirror sheet and I am using a pre-cut 20mm square.
The design is fairly straightforward, so I just came up with a modified design in OpenSCAD.
OpenSCAD design file:
3D Printed Mirror Mount with Mirror
Mounted on Tello
So, I was all set to go out and take a look at my gutters......  charged my drone batteries, but forgot to charge the controller.  I didn't want to fly near the roof without without real joysticks (a bit of wind today), but I did take it for a quick spin using the virtual controls in the iPhone app and discovered that I have to tweak the design a bit.  The picture below shows that I've mounted the mirror too far forward (you can see around the edges of the mirror).
I do get a nice down looking picture (the steps going up to my backyard deck).  Oh well, back to adjust the design and charge the controller.  Guess that's why we need 3D printers.
Another thing that is obvious but I hadn't thought about - the image in the mirror is reversed.  Not a big deal for my purposes.
  • three-phase
    three-phase over 7 years ago
    Useful update, is there an option to reverse the picture in the controller software? I suppose they are quite basic and wouldn't have that option. Wouldn't be a problem for a snapshot and a photo editing package.
    Kind regards
  • three-phase
    Kind regards
  • ralphjy
    ralphjy over 7 years ago in reply to three-phase
    No, the controller application doesn't have a setting to reverse the image.  I'm pretty sure that they didn't expect this type of setup.  Good suggestion about using a photo editor.
