Feedback and Support
F&S Forum Reliable use of @ to mention another forum member
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Mon, 02 Feb 2026 23:29:03 GMT ETag: "0x8DE317E31FF1C26" Set-Cookie: .te.csrf=68Dh6vRkl-QX0fZjaqXGOkReAueMOdwZqi0xoJnbQd0; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_YxSNX1WzkJ91DhaX8Wr%2fbarLokMy4wJufLmh8Hr3SEmkgXAOzbvqlVx%2bDfCTcaaWKzkXCZbp0i%2bIoxLjaOAGcjgtu%2fVjbA2GyMptW3nC7JdZDa%2fXRVWjOBE36b%2fjoXlkyU%2b%2fVjc9YfrznhThDxWIaG5bzTafMKDKcjnNAAWNa5TLC3ytYtBGT1V2Br%2bWxwpLftYBMvinpTlUOX7k3%2fiA3cwQcFw1FQBKe%2fDniN0ae5yNiWtF2MafiVxY5DQLoyoejcRUHvaUesf7hKK%2bD%2bTVmg%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=31 Server-Timing: origin; dur=64 Server-Timing: ak_p; desc="1770074943791_34604952_1983521582_9502_6287_6_7_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Locked Locked
  • Replies 7 replies
  • Subscribers 18 subscribers
  • Views 389 views
  • Content Creation
  • mention
  • Feedback or Suggestion
neilk
neilk over 6 years ago
Some members don't appear when you try to mention them using the @ character
The most recent one in BigG - apologies to you for using you as my example
If I type @BigG I get a list of members, beginning with biggdan and ending with bradbiggs, after requesting 5 more, but no BigG?
I've seen this problem with other members, but haven't had the time to follow it up
Neil
  • cstanton
    cstanton over 6 years ago +6 verified
    This's a Jive CMS platform bug that we've tried to raise with them to get fixed, but they won't fix. The reliable way to tag people is to copy and paste their profile URL into content. For example if I…
  • 14rhb
    14rhb over 6 years ago in reply to neilk +3
    You are very welcome Neil. I thought it a bit daft when, for example, I wanted user xyz and the listing would show five users: xya xyb xyc xyd xye and an option for more ...under more was always the one…
  • Fred27
    Fred27 over 6 years ago in reply to 14rhb +3
    Exactly. It's almost as if it's trying to hide the person you're actually after. Add to that the fact that the user name and display name can be very different (myself included) and it's often difficult…
  • 14rhb
    14rhb over 6 years ago +2 suggested
    Hi neilk , A very good discussion is in this thread August 2019 Site Update and I use it all the time now, I too found the previous method a bit hit-and-miss
  • neilk
    neilk over 6 years ago in reply to cstanton +2
    cstanton Thank you very much, that's so easy! Neil
  • neilk
    neilk over 6 years ago in reply to neilk +2
    14rhb Thanks! Your bit about hover and then copy makes it even slicker!! Neil
  • 14rhb
    14rhb over 6 years ago in reply to Fred27 +2
    At least your avatar is nice and distinctive to allow some confidence the right person is being selected. I wonder how many mentions are made or received by the wrong person !
  • cstanton
    0 cstanton over 6 years ago
    The reliable way to tag people is to copy and paste their profile URL into content. For example if I paste:
    https:// www.element14.com/community/people/neilk
    Without the space after the //, we get:
    neilk
    And you'll be tagged, and it'll create a link through to your profile page for anything to follow through to.
    • Vote Up +6 Vote Down
  • 14rhb
    0 14rhb over 6 years ago
    Hi neilk ,
    A very good discussion is in this thread August 2019 Site Update and I use it all the time now, I too found the previous method a bit hit-and-miss image
  • neilk
    0 neilk over 6 years ago in reply to cstanton
    Neil
  • neilk
    0 neilk over 6 years ago in reply to neilk
    Neil
  • 14rhb
    0 14rhb over 6 years ago in reply to neilk
    xya
    xyb
    xyc
    xyd
    xye
    and an option for more...under more was always the one I actually wanted e.g. xyz
  • Fred27
    0 Fred27 over 6 years ago in reply to 14rhb
    Exactly. It's almost as if it's trying to hide the person you're actually after. Add to that the fact that the user name and display name can be very different (myself included) and it's often difficult to mention someone. The paste idea sounds like a good workaround.
  • 14rhb
    0 14rhb over 6 years ago in reply to Fred27
