Feedback and Support
F&S Forum Careers
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Wed, 21 Jan 2026 06:59:04 GMT ETag: "0x8DE317E31FF1C26" Set-Cookie: .te.csrf=dUGfy3XGcFLI9C8ozXpL19Sq0YX48t35ke0NgL7IqTY; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_2RH4SOZOTDNxdFdr5YmStFgBT75hXFvGs%2fDiT%2fkxOcmi42fiVSCCpiq1y81rqCBJg4dtZPMgM1xpFC%2fqKEkyG5CwCoIs0khqSO65tbJsFZVevP5qKUdtwbMjQypX8racogN55KayaDBQoS7Cu%2bBxMfDRMQTcqbJrSEiW3jCstiQTuuZyunJ3lNrbYzB0fRtFPhHvCNCYB6W5vMKGkqDezf0KJGlWlrcEGS5%2fw9pt2PJIVKZ347DY1DyQQNXIcm6yNxREjtELxDtHsRGtyK6otA%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=30 Server-Timing: origin; dur=46 Server-Timing: ak_p; desc="1768978743952_34604941_209940793_7516_5375_4_17_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Locked Locked
  • Subscribers 15 subscribers
  • Views 293 views
  • website
  • careers
  • broken
  • bug
Careers
mcb1
mcb1 over 12 years ago
Looks like your careers page has some broken links, and appears to be missing some information.
  • element14jamie
    0 element14jamie over 12 years ago
    Hello Mark,
    Added to Ticket PRE-2056
    Thank you,
    Jamie
