Feedback and Support
F&S Forum No notification for mentions
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Wed, 31 Dec 2025 06:05:14 GMT ETag: "0x8DE317E31FF1C26" Set-Cookie: .te.csrf=2NOjYVUcQRJ1kQ1ofbC_sjhajLaUcLNdgYvLZ7mD_4c; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_sjS2QrRL6DZvKAdT2RY2eP9K2tgUvoKMrp0L%2fEcGvOUf5r%2b77%2fu4aWeGm8PwXHAHI4pNXxL7pSUiY%2bUYKKG%2b3wFAtWskZ%2fg5J6w7K%2fxbrmK7QuC7RXujAq%2bHvqMQbr32VmSc%2bL3nTqiZxn%2f5aBh1gGjPupwJFMheOVyVOmioLrB3nZz%2fYSq%2bQMjvvKsRb8EdT5TfaXWg3m9WkXpeSJFYvilVPgEVa1Y%2f5qeztEZciOdbN6wRb47zV6bjyoptn5bHbjdaCLyeRrmp8idj4YY5Mg%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=30 Server-Timing: origin; dur=47 Server-Timing: ak_p; desc="1767161114581_34604952_263613073_7664_6716_4_11_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Locked Locked
  • Subscribers 16 subscribers
  • Views 1468 views
  • Feedback or Suggestion
rsjawale24
rsjawale24 over 3 years ago
I was mentioned in Experimenting with Thermal switches challenge. However, I did not get the notification for the same.
It has been happening in every group, whenever someone mentions me, I don't get a notification.
I checked the notification settings, all the settings are set to ON.
  • cstanton
    0 cstanton over 3 years ago
    Hm. Your settings appear correct...
  • cstanton
    0 cstanton over 3 years ago in reply to cstanton
    I'll see if we can replicate the problem.
  • cstanton
    rsjawale24 Can you provide links where you were @ mentioned and weren't notified about it please?
  • rsjawale24
    0 rsjawale24 over 3 years ago in reply to cstanton
    Thanks! The links are as below
    /challenges-projects/design-challenges/experimenting-with-thermal-switches/w/documents/27440/experimenting-with-thermal-switches-challengers
    community.element14.com/.../the-element14-rising-contributors-of-2021
  • cstanton
    0 cstanton over 3 years ago in reply to rsjawale24
    It doesn't look as though you were properly @ mentioned in those so much as your user profile was simply linked to.
    Did you receive a notification that you were @ mentioned when I did so in the reply to this thread?
  • rsjawale24
    Ah! Got it. Those weren't @ mentions.
    But it's better to mention using @ so that the member gets a notification. I had missed my name as a rising contributor, got to know only when I visited the blog post.
    Yes, I received a notification for the mention in a reply to this thread. Thanks!
