Feedback and Support
F&S Forum Unsubscribe
  • Announcements
  • Site Updates
  • FAQ
  • Suggestions
  • Support Forum
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Tue, 24 Nov 2026 23:15:23 GMT ETag: "0x8DF300D76CC4AFB" Set-Cookie: .te.csrf=hQPz-JvF6kTfcDFcmmp-MP4rVY6-LTuyjl_3_I_u4Q0; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_p4Sda4MXD1KnrT8kqjFwPDgu%2bfcNT4Aqv%2beK2MBW%2fkwmxYbNR22euLhY5rCZY4wCrxzOq0AzH1Rqjcvauhm2VqaB6%2ftRVs%2fIq367zXDapAZhp3Z4PU9RPJ0jPiEGAzyjgpnFsjfvCyNN4sKj53m6LVxmFHbHO%2bsF1ToV2UFKqDAAYfFfWfZfhBNup0Vr4p%2fBcxLC8aDHDaLGOmt%2fIIIR0e%2fJeEhekIQ9AIKrDKVZHstHc22rugZ9PdzKyOK%2fgm8Xx9E5Jmy5IEBsXb5dCuazJA%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=59 Server-Timing: origin; dur=62 Server-Timing: ak_p; desc="1795562123445_34604952_732599423_12043_7317_3_14_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Locked Locked
  • Subscribers 17 subscribers
  • Views 391 views
  • Permissions
Unsubscribe
e14 Contributor over 3 years ago
I don't need this
  • cstanton
    0 cstanton over 3 years ago
    Hi  ,
    I'm aware that dychen  has reached out to you directly. Please can you at least provide more information as to what exactly you're wanting to unsubscribe from?
    You can find notification and subscription details on your user profile to self-serve, and if it's a newsletter you received there is an 'unsubscribe' link in the e-mail that you can use directly.
  • dychen
    0 dychen over 3 years ago
    I sent you a PM...let me know and I'll take care of it.
