Feedback and Support
F&S Forum Uploaded videos are not being processed
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Wed, 31 Dec 2025 05:42:40 GMT ETag: "0x8DE317E31FF1C26" Set-Cookie: .te.csrf=YIHiEp8whhGrcijrfnAZG44wzznibzCEP6C2FEfFnfA; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_T8M3czXyiw3gDYgZis15eT1S8eteQDpQ%2bBqoC%2fjOYYLybIjNNdAo0A2MzEMLg98JR4XoB1A96GxLzFgN8ywyP2M06Zl2H1LzwEXFQNAgFS03426E1w5d6kd3NoIu9ZMFDqdH7k3FvQulbH1GtuK0EIqDWcAtUcvvvlKXkFIX91fFS%2f%2btNNt3cIRzxKWTRE0hn7qv1kpelRy3Ml3IPBCqWNyuulsYHTTQ2zpC3X8vrivd6GFBq%2fucOqYVDkr5buaAxIno%2fhooFjAQV36XOqq6ZQ%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=34 Server-Timing: origin; dur=47 Server-Timing: ak_p; desc="1767159760517_34864907_280757199_8027_5060_4_9_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • +1 person also asked this people also asked this
  • Locked Locked
  • Replies 14 replies
  • Subscribers 16 subscribers
  • Views 1054 views
  • Report Bug
Andrew J
Andrew J over 2 years ago
Yesterday, I uploaded/embedded 2 videos into a blog that is draft status and they aren't being processed, just left as the normal "in-progress" grey box which seems to be the best way to describe it.  It's been almost 24 hours now so I guess there is an issue somewhere.
  • Andrew J
    Andrew J over 2 years ago in reply to scottiebabe +1
    You are going to be SOOOOOOOOOOOO disappointed! I'm beginning to feel a bit pressured here to come up with something now.
  • cstanton
    cstanton over 2 years ago +1 verified
    Hi Andrew J , Since the development release last night we have now been able to change the behaviour of videos embedded in drafts. You should now see at least a thumbnail when you're previewing your…
    +1 Jan Cumps over 2 years ago
    Processing starts when you publish the blog.
  • scottiebabe
    0 scottiebabe over 2 years ago
    T-24hrs to million dollar poduct launch, no one can see your draft!
  • Andrew J
    0 Andrew J over 2 years ago in reply to Jan Cumps
    Really???  Well, ok, guess I'll wait!
  • Andrew J
    0 Andrew J over 2 years ago in reply to scottiebabe
    Grin You are going to be SOOOOOOOOOOOO disappointed!  I'm beginning to feel a bit pressured here to come up with something now.
  • cstanton
    +1 cstanton over 2 years ago
    Hi Andrew J ,
    You should now see at least a thumbnail when you're previewing your draft and it should be a bit more obvious that it has embedded/inserted successfully, rather than the messaging before that it was still processing, when in fact it hadn't started yet.
    Hopefully this is a better experience.
  • Andrew J
    0 Andrew J over 2 years ago in reply to cstanton
    Hi Chris,
    I've added a video into a blog post that is save as draft, and looked at the preview and it shows a grey box with "Video is being Processed.  It will be available soon."  This was a draft blog I started a few days ago, but I've just added a new video into it.
  • cstanton
    0 cstanton over 2 years ago in reply to Andrew J
    Can you provide a link to it please?
    0 Jan Cumps over 2 years ago in reply to Andrew J
    Video's start processing after publishing on the forum.
  • Andrew J
    Yes, but as Chris said, they made a change to show a thumbnail when looking at a blog preview.
  • Andrew J
    Ah, I’ve actually published it now.  What I’ll do is create a new post with an image and see what happens.
  • Andrew J
    0 Andrew J over 2 years ago in reply to Andrew J
    Here you go: you can see the video behind the preview window and neither show a thumbnail.  If you can see draft posts it's here: View
