Feedback and Support
F&S Forum When creating a blog and inserting a table of contents, spurious TOC entries can be created
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Sun, 29 Mar 2026 06:15:21 GMT ETag: "0x8DE62FB5D5EDB64" Set-Cookie: .te.csrf=X5jOiysI-z_bXC-fi7kZMEvc2iMrs7wd84SAYXB--Nc; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_yjrcvb2Xxz70C9Debi4zo%2bc8XFW9iCH0vavdc1n%2fGVvduOrHrwnYSO7YeK5sRtTfTV8nXFfqmJjTZceoERgesGF5a7Ns4cR%2bgS72x3ahVoeokofYTStmf8WedBrZPWjrllxM15FDsoZpCUpJcOGTTmwsS39fNNJa358xQNaETsi%2b6hzjlM6pC8s%2b3KLsCKpLjxZtOr7SQ9Hatj7nQEbKRnoM0N33A2%2ff7pvxqNz2tQoYBJuc%2fCi%2bG%2bIYYz8BWURbB4tgEQOPcOZqb8ZCF9TYlw%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=32 Server-Timing: origin; dur=45 Server-Timing: ak_p; desc="1774764921698_34864915_416836243_7643_4542_3_8_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • +1 person also asked this people also asked this
  • Locked Locked
  • Subscribers 16 subscribers
  • Views 488 views
  • Report Bug
Andrew J
Andrew J over 2 years ago
See this example test blog:  /members-area/b/blog/posts/test-of-table-of-contents-problem---spurious-entries-created
I think it happens when there is a "missing" heading level between one level and another, e.g. when going from text under a Heading 3 to a Heading 1 without an intervening block of text at Heading 2 level.
  • cstanton
    cstanton over 2 years ago in reply to cstanton +1 verified
    This has been escalated to Verint as it's a bug with the platform, I do not have an ETA on a fix or a timeline of when it will be addressed.
  • skruglewicz
    0 skruglewicz over 2 years ago
    I found to be true but never analyzed it. It is annoying. Hope they fix the editor...
  • cstanton
    0 cstanton over 2 years ago
    Thanks Andrew J ,
    I've taken the link to your example blog and the issue you've laid out here and raised it with the development team to investigate and hopefully fix.
  • cstanton
    +1 cstanton over 2 years ago in reply to cstanton
