    Members
    • Experts & Guidance
    • Avnet Boards Community
    • Or choose another store...
Feedback and Support
F&S Forum Missing comment, yet it appears in Top Comments?
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Fri, 01 Dec 2023 13:33:43 GMT ETag: "0x8DBE573EDBA1945" Set-Cookie: .te.csrf=266D7zwYmIWbNziOHSx5dI2i48fRdlYGcRf9keJxFeU; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=Xnb9bnSHPPMaH1u43lFGYVYUOmvbqqydKbXrGmRpSxIJAsaOCHG314crcMDzhjCmgc62UnHyoxd9Gqprn26VYPR7ipEQ6FQkmifKT73aiGjJR%2bTF5OTt7LTXiVCqCiUYxsHL7Y6lm0qWa%2fmPHsjb9IT%2bP2GLbRIf3t7khQzbakqsaxWTwM9RO9GWUI7O8zpFI2nSAW29xyesHQTuc8sOEsNGcm7%2fxvlGxFV0k9paWMFpmirJypT952s3KTkoscALUTHMEYaJ0s5uO8Na9lUy4A%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=5 Server-Timing: origin; dur=19 Server-Timing: ak_p; desc="1701437623206_34697231_209407519_2450_3565_2_7_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Replies 11 replies
  • Subscribers 16 subscribers
  • Views 202 views
  • Report Bug
shabaz
shabaz 20 days ago
At this blog post: /products/devtools/ni-labview/b/labview-challenge-blogs/posts/labview-challenge-a-course-in-labview-and-test-automation-blog-1
I see this:
However, I cannot see the comment by @cstanton anywhere further below. I thought the top comment was simply a copy of a comment further below in context along with all the other comments, but I cannot see it (maybe I'm going blind but I checked a few times!).
Have I missed it, or is it really missing? Is it a bug? Or have I simply not seen it but it's there? I clicked on any "View more" that I could find, but I still couldn't locate that comment.
I just thought I'd report it in case it's an issue.
  • Reply
  • cstanton
    cstanton 13 days ago +2 suggested
    Thanks everyone for the detailed checking with this. I've been able to reproduce this, and I've raised it with the development team.
  • cstanton
    cstanton 20 days ago +1
    Hi Shabaz, Can you try clicking on this link for me please to see if it takes you to the comment? /products/devtools/ni-labview/b/labview-challenge-blogs/posts/labview-challenge-a-course-in-labview-and…
  • beacon_dave
    beacon_dave 19 days ago in reply to shabaz +1
    Here, 'Best' appears to be filtering it out. 'Oldest' or 'Newest' reveals it. Perhaps give that a try your end ?
    shabaz 19 days ago in reply to beacon_dave +1
    I have both of them defaulted to "Best" (I never changed that from the default): However scrolling them both down, only one of them has those missing comments. Which begs the question, is Best supposed…
  • beacon_dave
    Yeh, but does 'Oldest' or 'Newest' reveal it for you ? Looks like it could be related to your issue.
    I clicked on 'Oldest' and I could find that comment, but who knows if a different one is missing now : ( I don't really want to try working around this, or assuming that it is worked around, because from…
  • beacon_dave
    Yeh, I'm seeing the same as you. Following the bare URL and the post disappears with the default 'Best' setting. Selecting 'Newest/Oldest' reveals it. Following the URL with the comment ID in the…
    I too would normally debug further but didn't have time to do a thorough job so didn't want to half-debug, i.e. now that it's known reproduceable anyone who can troubleshoot further can make the thorough…
  • beacon_dave
    Not sure if it is related issue or not but I've been noticing that I've been getting an increasing number of in-line ' View More ' prompts appearing yet when you select it you just get the ' There…
    shabaz 13 days ago in reply to cstanton +1
    Hi Christopher, Thanks for checking!
  • cstanton
    0 cstanton 20 days ago
    Hi Shabaz,
    /products/devtools/ni-labview/b/labview-challenge-blogs/posts/labview-challenge-a-course-in-labview-and-test-automation-blog-1?CommentId=48336666-593c-4714-950a-f65e1005345f
    Thanks.
    • Reply
    0 shabaz 20 days ago in reply to cstanton
    Definitely a weird one.. with the link you gave, I see your comment, plus one from Jan above yours. This is on the left in the screenshot below. However if I click on the original link, it appears to be missing your comment and Jan's beginning with "Should I apply?". I double-checked and both are at the default of sort by "Best" (I never change that default either).
    • Reply
  • beacon_dave
    0 beacon_dave 19 days ago in reply to shabaz
    • Reply
    0 shabaz 19 days ago in reply to beacon_dave
    Which begs the question, is Best supposed to be filtering things out? If so, that's unexpected behavior (since most websites use "sort by", and not "filter by"). It doesn't make sense anyway since it was a "Top Comment" and yet not on a "Best" list.
    I think this must be a bug.
    • Reply
  • beacon_dave
    • Reply
    I clicked on 'Oldest' and I could find that comment, but who knows if a different one is missing now : ( I don't really want to try working around this, or assuming that it is worked around, because from experience that may result in some other problem occurring later, if the root cause (whatever that is) is not fixed, or if I've mistakenly assumed that 'Oldest' is a complete fix when that may have an issue too that I cannot notice because I've not thoroughly tested in the way a tester might.
    I'm just glad it's not just me, i.e. it is a repeatable issue if you too see the same thing when 'Best' is selected.
    • Reply
  • beacon_dave
    Following the URL with the comment ID in the URL Query and the comment is displayed with the default 'Best' setting.
    Selecting 'Newest/Oldest' keeps it revealed, but that removes the comment ID from the URL Query and adds the Sort By / Sort Order entries.
    Selecting 'Best' and the comment disappears again.
    I was just trying to collect some more info about the behaviour for Christopher to pass on.
    • Reply
    I too would normally debug further but didn't have time to do a thorough job so didn't want to half-debug, i.e. now that it's known reproduceable anyone who can troubleshoot further can make the thorough investigation.
    Had a waste of a half hour just now, trying to reproduce a bug on a piece of equipment. It occurs just frequently enough to be irritating, and not frequently enough to be sure of how I caused it.
    The two times the bug occurred today, I didn't capture it : ( And for the past half hour I cannot repeat it : (
    • Reply
  • beacon_dave
    Not sure if it is related issue or not but I've been noticing that I've been getting an increasing number of in-line 'View More' prompts appearing
    yet when you select it you just get the 'There are no more remaining comments.' prompt appearing
    I'm mentioning it here as it is happening on the page being referred to here and so may be caused by the comment filtering that appears to be occurring.
    e.g. the 'View More' part of the code is counting Christopher's non-displaying comment but then 'There are no remaining comments.' part of the code is showing as a result of the comment having been 'filtered out' from display and then there is nothing left to display after that.
    Know what you mean about chasing intermittent bugs. Spent over year chasing one which could randomly appear in the control system of any one of eighty plus venues at any time of the day but usually outside of normal working hours. So added complication of getting from home to work through road works, signing out of building access keys from security lodge, etc. before you could even get to the equipment to start figuring out what was going on, and all against the clock.
    • Reply
  • cstanton
    0 cstanton 13 days ago
    • Reply
    0 shabaz 13 days ago in reply to cstanton
    Hi Christopher,
    • Reply
An Avnet Company © 2023 Premier Farnell Limited. All Rights Reserved.
