    Members
    • Experts & Guidance
    • Avnet Boards Community
    • Or choose another store...
Feedback and Support
F&S Forum Disabled Verify Answer
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Fri, 01 Dec 2023 14:01:37 GMT ETag: "0x8DBE573EDBA1945" Set-Cookie: .te.csrf=5Drz2Eg18Q4pAHV9cveaqTR9L1K0mFFu1-fk_wcv8EU; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=GEhHSJ9uTi5E%2fHvlV6RzgT769o%2fROfwfUnK1Yp0kdkMphPFB3iYQL5d5r7Iz%2bfFJwdLEa2kQAMSdZLzIeXd5O8fED%2fh%2brXseiUt4cR8X1qjT2o2sEwb43vh4VRtzUAkApjSr8RGtVcsNUCE68fMmPh8g%2bbI0Oxu8Y4iXb6IvXXEx0V7YmsQQqjPJF9OFcLGIlsYZna9S5g7muE6tYKfb3NaiAxWi87h5%2fdq3IoA3tCMnEUK1E4Cag3s2QAkFjUR2fIjQebOq9SgsBoBfUp94bg%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=7 Server-Timing: origin; dur=29 Server-Timing: ak_p; desc="1701439297297_1600474645_52406984_3584_2717_2_12_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Replies 9 replies
  • Subscribers 16 subscribers
  • Views 162 views
  • Verify answer
  • solved
abhishek2018
abhishek2018 20 days ago
Verify answer option needs to be enabled for questions solved in design challenge
  • Reply
  • cstanton
    cstanton 17 days ago +3 verified
    Hello, "question and answer" topics have now been enabled for the Experimenting with Flyback Transformers forum, do let us know if it's missing anywhere else. Thank you.
  • Gough Lui
    Gough Lui 16 days ago in reply to abhishek2018 +2 verified
    Because they are two separate content types. Question "type" has the "Mark answer" feature. Discussion "type" does not. This is how Verint has always worked. If the thread was built as a discussion…
  • cstanton
    cstanton 16 days ago in reply to Gough Lui +1
    This is correct. Thank you.
  • cstanton
    +1 cstanton 17 days ago
    Thank you.
    • Reply
  • abhishek2018
    0 abhishek2018 16 days ago in reply to cstanton
    Ok
    • Reply
  • abhishek2018
    It is still missing,
    • Reply
  • Gough Lui
    0 Gough Lui 16 days ago in reply to abhishek2018
    What cstanton meant was the "Question and Answer" thread type is enabled for Experimenting with Flyback Transformers.
    Any existing threads need to have their type changed in order for the options to show up.
    - Gough
    • Reply
  • abhishek2018
    0 abhishek2018 16 days ago in reply to Gough Lui
    Thanks Dr. Gough Lui, he has used word 'forum'.
    ok Enabled only for Question and not discussion, Does this he meant ?
    But why not for discussion.
    • Reply
  • abhishek2018
    0 abhishek2018 16 days ago in reply to abhishek2018
    • Reply
  • Gough Lui
    +2 Gough Lui 16 days ago in reply to abhishek2018
    If the thread was built as a discussion type, then there will be no "Mark answer" feature.
    - Gough
    • Reply
  • cstanton
    0 cstanton 16 days ago in reply to Gough Lui
    • Reply
  • abhishek2018
    ok , you can lock
    • Reply
An Avnet Company © 2023 Premier Farnell Limited. All Rights Reserved.
