Pls see
Datasheets-Experimenting with Flyback Transformers
File upload in Design challenge still in moderation and new with Revision 1 is still not showing
Pls see
not yet
Hi abhishek2018
This appears to be visible at Datasheets-Experimenting with Flyback Transformers and working fine for anyone who wants to download it.
Could you explain further what behaviour you're expecting to see which isn't happening for you?
See 5 images,
{gallery}My Gallery Title |
I have forgotten 2 pdf as you can read. So, I changed the new zip from 'Datasheet_Flyback+Transformers.zip' to 'Datasheet_Flyback+Transformers_Rev1.zip'.
You can see all steps followed, even I had tried with change file option and then clicked post. But you can see at this time also, the older zip is only able to get downloaded.
2) I have tried with complete new file, with even title 'Revision 1" but after all upload, the message popped, '' you have posted in image gallery, moderation..." something like that and that post is still not visible.
I reuploaded, now its showing correct zip download.
And the Second post seems lost or bot has hold it.
