Feedback and Support
F&S Forum Email inconsistencies.
  • Announcements
  • Site Updates
  • FAQ
  • Suggestions
  • Support Forum
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Tue, 24 Nov 2026 23:17:18 GMT ETag: "0x8DF300D76CC4AFB" Set-Cookie: .te.csrf=WaUVMP39HpILkB86qderIGgae-h_piIf0cnMjiYD0ts; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_CcSga0y%2fxY2oHiFgOmmPxXHQIvM%2bSNwRHwzHa9g8qDyVRTQDu6wrJLlnTwAaBjk3U1ESHgu6npfEbZ%2biayoRhBHBwai6xU%2bcFMlPLUbBeDQiKwmLXY4L569qOqFHuFr3g7NBTTYXbEft7vhQksQLzEoRmfUK%2f1%2b7KuTaYMb0j3TXZD6esdDDaIVB2LrWLXvWaclKv%2b4rxRBN9JM79uDkYe7yM82Xt9mOgS%2f4A46gl%2b0BwNxQCVV2hZsGuFZm1GM2Z4EYirRkXiT%2feOROGo%2fkjw%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=28 Server-Timing: origin; dur=46 Server-Timing: ak_p; desc="1795562238062_34604941_433291951_7387_5324_8_16_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Locked Locked
  • Subscribers 17 subscribers
  • Views 463 views
  • Email Notifications
anniel747
anniel747 over 2 years ago
Someone knows why the emails look different?
  • cstanton
    0 cstanton over 2 years ago in reply to anniel747
    Hey anniel747 ,
    Could you:
    1. Confirm what you're using to view the e-mails.
    2. Possibly send the original e-mails as an attachment than supplying the text of the e-mail?
    And have you had this problem since?
  • anniel747
    0 anniel747 over 2 years ago in reply to cstanton
    Sent you two messages. I noticed the "Received: from" IP is not the same.
  • cstanton
    Hi anniel747 ,
    I have no idea. It looks like they are using the same template - so there should be no difference between the e-mails.
    It looks as though it is missing some HTML or perhaps a HTML tag has been removed, malformed or adjusted somehow and in some way.
    You're welcome to export these e-mails and send me a direct message with them with the HTML intact so that I can inspect them, but I would have expected these to have been rendered correctly as they should have pretty much contained the same thing.
